Mk2 door rubber seals
Old Jun 18, 2021 | 12:05 PM
Brian53's Avatar
Default Mk2 door rubber seals
Could anyone confirm which way around to fit mk2 door seals. The profile of the rubber seals is a flat bottomed U shape with one of the legs longer than the other. The information I received from SNG shows all seals are fitted with the longer leg of the seal to the inside of the door opening. This is ok generally but seems to cause interference on the A pillar and the rear of the B pillar as the doors are closed. Can anyone clarify the correct orientation. Thanks
Old Jun 21, 2021 | 02:26 PM
Jose's Avatar
use these if you can't make the repros work.
https://www.classic-motor-cars.co.uk...-seal-kit_3938
redtriangle
Mar 31, 2023 01:53 PM
Jagpassion92
Mark V - X 420G
Oct 6, 2016 03:33 PM
barrymk2
Oct 2, 2014 06:18 AM
Katoh
Jun 27, 2013 03:03 PM
Nov 29, 2005 11:10 PM
