Paint code
Old Feb 13, 2018 | 04:56 PM
domain58's Avatar
Default Paint code
Hi from down under,
My 1964 Daimler sedan paint color is Old English White. Can any forum member tell me the factory paint code for this color.
Thank you.
DB
Old Feb 14, 2018 | 02:56 AM
StuG's Avatar
Originally Posted by domain58
Hi from down under,
Thank you.
DB
It seems like different paint manufacturers supplied the paint and they used different codes. PPG/Ditzler Paint show two different codes for Old English White (JAGUAR/DAIMLER PAINT CODES FOR PPG/DITZLER PAINTS).
I took the codes and one of the spats off the MK2 and took them into my local Autobarn. They were able to provide a perfect match and gave me a print out of the formula in case I ever need more paint.
Hope this helps.
Cheers,
Stu
Old Feb 14, 2018 | 08:07 PM
domain58's Avatar
Default paint code.
Hi Stu,
Thanks for the reply. Was your car Old English White? If so what was the paint code. I had some paint mixed by my local Autobarn and put in a spray can but the end result was too white not all like my car.
Regards,
DB. Noosaville.
Old Feb 14, 2018 | 08:51 PM
StuG's Avatar
Hi David,
Yes, my car is Old English White, but it wasn't always. One of the previous owners changed the colour from Mist Grey.
I've attached the tinting formula from Autobarn that matches my car. Not saying it is going to match yours.
That's why I suggested taking off one of the spats and taking it into the shop. There are different formulas for OEW.
Cheers,
Stu
File Type: pdf
Old Feb 14, 2018 | 09:40 PM
domain58's Avatar
Default paint code
Hi Stu,
Thanks for the very prompt reply. You say you took a wheel spat to get the paint matched. Did they use a formula to mix the paint then checked it against your sample or did they eye match the paint. I used to own an Autobarn franchise so am familiar with the process.
Regards,
David Bruce.
Old Feb 14, 2018 | 09:50 PM
StuG's Avatar
I gave them the PPG/Ditzler paint codes (8233 and 8894). They mixed a little bit of one and it didn't match. The second one matched exactly. They didn't put it in a spray can until they had a match.
Old Feb 16, 2018 | 10:36 PM
domain58's Avatar
Thanks again for the prompt. reply.
David B.
XxSlowpokexX
Apr 10, 2019 11:11 AM
philhef
Oct 25, 2013 11:27 AM
Calhale
Jan 22, 2013 06:33 PM
jagosaurus
Sep 25, 2012 06:50 AM
christer200
May 14, 2009 04:40 PM
