Radiomobile crank aerial
Old May 17, 2014 | 05:56 PM
MK2's Avatar
MK2
Default Radiomobile crank aerial
Hello all,
With the help of some great Jaguar friends I have a rebuilt (working perfectly) winder box for my hand cranked radio aerial. However, I am missing the pieces of the aerial mount that fit on the outside of the fender (wing). I have attached a photo from a car that has what I need. I am happy to pay a fair price for the needed components if anyone can help. Anyone have what I am looking for that you are not using?
Thanks very much.
Lin
Old May 18, 2014 | 10:14 AM
Jose's Avatar
if you mean the black rubber gasket/seal, the black half-moon plastic "ball", the chrome cover, and the chrome nut, those look to be generic parts found in any replacement antenna that you can purchase most anywhere. I don't think those were "Jaguar-designed" or exclusive-to-Jaguar parts. Most cars of the period had the same antenna, whether manual, or cranked, or electrically-operated, the mounting hardware is the same.
I have a manual antenna that came in my first car, a 1969 MG-B Mark 1, and the exterior pieces look identical to the picture you posted.
Old Jun 6, 2015 | 01:58 PM
pennsy123's Avatar
Default Antenna
Sorry to say I don't have any spare parts,but I do have a MK2 with that antenna and would like know how to remove it without damaging it. I also would like to know where the winder box sits and what is it attached to.
Old Jun 6, 2015 | 03:44 PM
Jose's Avatar
should be obvious how to remove it, 3 screws for the crank assembly, 2 screws for the mast, and the chromed nut.
Old Jun 8, 2015 | 03:32 AM
Hartford6's Avatar
I too have a hand crank aerial fitted to my Mk2 but is different to the one shown by Jose. They are like 'Hens Teeth' as most people I have spoken to do not have one fitted or worse know anything about them. Mine is fitted just under the dashboard very near to the bonnet (Hood) release. I found it whilst messing about to cure my lost power problem.
I recently came across a dealer in the UK selling a electric version from 1960 made by Radiomobile for £165.00 I was very tempted as the crank from mine is missing.
Hope this helps
Ian
Old Sep 18, 2015 | 05:10 AM
John Francis's Avatar
The antenna pictured above is a German Hirschmann (not a Smith Radiomobile) that were a accessory for Porsches etc. The Smith ant. crank box is secured with a large nut/washer, the mast is secured with a nut at the bottom and a friction fit ball and grommet at the top. See MK2's site: Radiomobile Radio, Aerial and Housing ? Valve Chatter
Old Sep 18, 2015 | 05:54 AM
[QUOTE]Sorry to say I don't have any spare parts,but I do have a MK2 with that antenna and would like know how to remove it without damaging it. I also would like to know where the winder box sits and what is it attached to.
Due to corrosion of the mast lower mounting nut, it maybe be better to remove the mounting bracket and mast as one, either unbolt( MK IX etc.) or drill out spot welds (MK II etc.), and try and free up the nut out of the car.
Old Sep 19, 2015 | 06:57 AM
MK2's Avatar
MK2
Default Radiomobile crank aerial Reply to Thread
These photos show where the winder mechanism is located on my car which is LH drive. The photos also show the location of the lower mount for the aerial mast. Hope these help.
Lin
https://www.flickr.com/photos/valve-...57646455745530
oldjaglover
Dec 25, 2024 04:33 PM
Presence
Mar 13, 2016 02:21 PM
PhilXJ6
Jan 3, 2016 08:55 PM
rocket1lf
Sep 29, 2015 09:16 AM
