Removing clutch fork from bellhousing
Old Apr 24, 2013 | 04:53 PM
anjum's Avatar
Default Removing clutch fork from bellhousing
Hi,
How do you remove the clutch operating fork from the bell housing in a mak2 jaguar gearbox (with overdive). Seems to be bushed in but can't get a drift in there.
I'm trying to get the bellhousing off and one of the bolts is under the clutch fork.
Old Apr 24, 2013 | 07:52 PM
on edge's Avatar
Hi Anjum there should be a spring clip on each end of fork where it pivots; prise these out with a screwdriver making sure they dont ping off and lose them. This will remove the thrust bearing.In the centre of the fork there is a lock nut with an allen key undo these and you should be able to drift it out thru the hole provided in bellhousing.
Cheers Ray from down under
Old Apr 24, 2013 | 08:16 PM
anjum's Avatar
Thanks Ray,
I didn't see any hole for access to the bushes, I will put my glasses on and check again tomorrow.
Old Apr 25, 2013 | 03:28 PM
anjum's Avatar
Found the hole!!!!
Someone had snapped the grubscrew so I had to carefully drill it out.
It was difficult to drift it out as you have to drift it towards the hole as it wont come out the other way. I used a series of things as drifts till it came free enough to pull out. Not much space to apply a hammer either.
Many thanks Ray.
Old Apr 26, 2013 | 05:10 AM
on edge's Avatar
Hi anjum glad you got it sorted
cheers Ray
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Phil G.
Sep 12, 2015 07:42 AM
Greg Reed
Sep 11, 2015 08:41 PM
1964Daimler
Sep 9, 2015 11:28 AM
