Rev counter generator
Old Jan 23, 2016 | 09:02 AM
rtipping's Avatar
Default Rev counter generator
19613.8 mk2.
Does anybody know if you can run the engine for a while with the rpm generator physically removed??
Old Jan 23, 2016 | 10:53 AM
JeffR1's Avatar
It will eventually leak oil from that area. There's an "O" ring seal on the rev counter that will be gone.
Old Jan 23, 2016 | 04:12 PM
Curmudgeon's Avatar
If you need to run it a long time, like drive over the river and through the woods, measure the OD of the generator, find a rubber freeze plug (core plug) that expands with a nut. Stick it in the hole and tighten enough to hold it securely.
Reverse procedure to remove!
Old Jan 25, 2016 | 12:40 PM
rtipping's Avatar
Took the car to a show probably 100kms or so, there is a fine oil splatter but not too serious. Now to figure out why the generator will not engage with the slot in the cam!!
Old Jan 25, 2016 | 03:31 PM
Curmudgeon's Avatar
Bushing moved. Had it happen. Mine did it 40K ago, locktited it back into place, so far, so good.
dc4prez
Feb 20, 2016 06:06 AM
Addicted2boost
Jan 24, 2016 05:35 PM
JaguarXKR
Jan 24, 2016 05:25 AM
NTL1991
XJ40 ( XJ81 )
Jan 23, 2016 06:05 AM
caunyd
Jan 19, 2016 01:59 PM
