1993 jaguar xj6 (The knocking continues) Help
Old Feb 1, 2014 | 09:08 AM
stillfree79's Avatar
Default 1993 jaguar xj6 (The knocking continues) Help
Hello,
I am new to the forum but a frequent visitor. I have a 1993 jaguar xj6 in pretty much mint condition with only 88k I have recently done a lot of maintenance to it my self. From front to back as follows new cooling fan regulator, and module, new belts, new front shocks, bushings, and breaks. New rear struts, and bushings. New spring top plate, and new sub-frame bushings. I initially started with the rear struts thinking the loud knocking sound coming from the rear of the car on drivers side. (sounds like right above strut in trunk) would go away.
The noise continues even after all of the repairs. I have checked the a-frame bushings and they appear to be fine. There is a control arm im guessing that goes from rear end to the body aprox 12in long with bushings on each end that appear to be weak but i can not figure out what they are called to look up the part or bushings. Any info on this part or the problem that might be making the noise would be great. Thanks Scott
Old Feb 1, 2014 | 09:33 AM
Welcome to Jaguar Forums stillfree79,
I expect you know where the tech section but here's a link just in case XJ40 - Jaguar Forums - Jaguar Enthusiasts Forum try and check our regional section also North East US - ME NH VT MA RI CT NJ NY PA - Jaguar Forums - Jaguar Enthusiasts Forum
Old Feb 1, 2014 | 10:05 AM
MidwestJag's Avatar
Glad to have you with us, Scott:
It's nice to hear about an XJ40 receiving such loving care. Sounds like a great car, and I'm sure you'll eventually get to the bottom of your noise.
See you around!
Scott
Old Feb 1, 2014 | 10:58 AM
Welcome to the forum Scott,
Good to have you with us at Jaguar Forums and to hear you've already found useful information here.
The 'HOW TO' thread at the top of the XJ40 tech section https://www.jaguarforums.com/forum/x...ck-links-5911/ is a good place to start for info on regular issues.
Enjoy the forums.
Old Feb 1, 2014 | 11:01 AM
welcome to the forum - you will find plenty of info and support here simply follow the links Norri and Graham have provided - enjoy!
Old Feb 1, 2014 | 07:17 PM
search facility etc, can be found here within the following link Helpful_information
Old Feb 2, 2014 | 08:38 AM
Thank you. I hope i will as well. Yes I do love the car and it has been good to me. I just replaced the valve cover gasket in hopes to stop some of the oil leak problems this make has also.
BrentGardner
29
Dec 16, 2024 12:13 AM
rusty37
Jun 7, 2016 04:43 PM
casepie
Aug 30, 2015 09:49 PM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
Jaguar Forums Editor
Jaguar Press release
Aug 27, 2015 03:18 AM
