2001 jaguar xk8 gearbox fault/restricted performance
Old Apr 6, 2017 | 02:12 AM
Bodayga TV (BODAYGAdotcom)'s Avatar
Default 2001 jaguar xk8 gearbox fault/restricted performance
I officially hate this piece of **** car. It all of a sudden went into limp mode as I was driving one day. Now when I put it in drive, the engine has to rev up to 3000 rpm before it does a hard shift into what seems to be 5th gear. I say this because it pulls off very slowly and it never shifts. GEARBOX FAULT/RESTRICTED PERFORMANCE, is what it says. I put in brand new plugs and a brand new battery. Any suggestions before I start parting it out or find a Louisiana lake to bury it in? 318-294-7246
Old Apr 6, 2017 | 02:44 AM
Welcome to the forum Bodayga TV,
I've deleted NINE identical posts like this you've made across various forums. Any more and it will be a very short stay here for you.
Follow this link XK8 / XKR ( X100 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the XK8/XKR forum for help, advice and information.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Southern Midwest Region forum by following this link US Southern Midwest - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Apr 6, 2017 | 03:56 AM
Welcome.
That ZF transmission is well known to have issues if the fluid is not changed regularly. His direction to the correct area will give you the answers.
Old Apr 6, 2017 | 05:49 AM
welcome to the forum
Old Apr 6, 2017 | 11:13 AM
Welcome to Jaguar Forums Bodyaga tv,
Old Apr 6, 2017 | 05:41 PM
Daf11e's Avatar
Welcome aboard.
Old Apr 6, 2017 | 08:02 PM
Old Apr 6, 2017 | 09:14 PM
JBzXJ40's Avatar
Welcome to the forum.
Your symptom sounds like the front drum inside the trans has cracked/broken and will need to replaced or rebuilt, known issue with those transmissions.
Old Apr 7, 2017 | 05:29 AM
o1xjr's Avatar
Old Apr 23, 2017 | 10:58 PM
I apologize for that. I was very frustrated
Old Apr 24, 2017 | 03:08 AM
I got a subtle hint you were upset at the time.
There's three regular issues on the XK8/XKR:
1. cooling system (water pump impeller/thermostat)
2. tensioners (early plastic type)
3. transmission (so called 'sealed for life')
With these checked/resolved, the XK8/XKR is a great car to own and run.
There's a couple of suggestions in the above replies on where to start troubleshooting the GEARBOX FAULT issue. I think you could be looking at a transmission rebuild.
Frustrating and annoying but worth considering as an alternative to the Louisiana lake. Post the question in XK8/XKR forum and you will get help and advice on repairs.
