2008 X-type 3.0 Error Codes P0352 P0354 P0356, & P1368
Old Mar 11, 2019 | 11:38 AM
dbourg's Avatar
Question 2008 X-type 3.0 Error Codes P0352 P0354 P0356, & P1368
Hi everybody. I'm a new member. First time posting but i've frequent this forum. Up until recently, my car has been flawless. Now I'm getting multiple error codes. up to 12 codes at a time but P0352 P0354 P0356, & P1368 are consistent. I understand them to mean bank 2 (left) is having misfires. I've checked for vacuum leaks. change upper & lower intake manifold gasket, IMT gaskets, and chased down the wiring all the way back to the ECM and didn't find bad wires. P1368 says a Ignition amplifier, bank 2 could be a problem. Does this car have an ignition amplifier or does the single come from the ECM?
An interesting fact is when i clear the codes at a high rev, the engine runs fine until i let off of the accelerator and then re-accelerate. then it goes back to running poorly. which leads to me it'as not a vacuum leak.
Any help is appreciated.
Old Mar 11, 2019 | 03:54 PM
Welcome to the forum dbourg,
A re-post in X-Type forum will get this to the attention of members with the same model. Follow this link
https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Southern Midwest Region forum by following this link
https://www.jaguarforums.com/forum/u...rn-midwest-67/ to find other members in your region.
Enjoy the forums.
Old Mar 11, 2019 | 05:57 PM
o1xjr's Avatar
Welcome to the forums.
Old Mar 11, 2019 | 07:50 PM
Hello,
I know how frustrating it is to have error codes for no apparent reason.
However, I'm sure you'll have them all sorted out with the help you find here.
Old Mar 11, 2019 | 08:03 PM
Welcome to the Forums.
Old Mar 11, 2019 | 11:35 PM
Daf11e's Avatar
Welcome aboard.
Old Mar 12, 2019 | 04:44 AM
Welcome to Jaguar Forums dbourg,
Old Mar 12, 2019 | 06:38 AM
Old Mar 21, 2019 | 12:59 PM
dbourg's Avatar
I still have not found the problem. Can any of you tell me the significance on the ECM number? I found many that should fit by application but the part number varies a bit. I need JAG# 8X43-10K975-AA (DENSO MB079700-9670). Will any fit by application and will they work without reprogramming?
Old Mar 21, 2019 | 02:13 PM
The ECM is both Market and VIN range specific. In addition, it is a programmable module and will not "plug & play".
JHenry313
Sep 23, 2021 11:04 AM
FHP
Sep 14, 2020 12:45 PM
mystype04
Apr 11, 2019 08:46 AM
blackhonor9
Apr 4, 2015 05:03 AM
misham64
Oct 17, 2010 01:37 PM
