2014 JAGUAR XJL Light level indicator light on dash intermittent
Old Nov 7, 2022 | 11:12 AM
MKLJKLFOUR's Avatar
Default 2014 JAGUAR XJL Light level indicator light on dash intermittent
Has anyone else had this issue with the light level indicator light coming on intermittently. It is yellow looks light a headlight.
Looked it up and believe it is the level indicator that is associated with the suspension.
Would like to know where it is located and will fix myself. Thanks for any help on this matter.
Old Nov 7, 2022 | 05:31 PM
Welcome to the forums MKLJKLFOUR,
This one?
Follow this link https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the X351 forum for help, advice and information. You can also use the US Midwest Region forum by following this link https://www.jaguarforums.com/forum/us-midwest-39/ to find other members in your region.
Enjoy the forums.
Old Nov 7, 2022 | 05:43 PM
Daf11e's Avatar
Welcome aboard.
Old Nov 8, 2022 | 05:03 AM
Welcome to the Forums.
Old Nov 8, 2022 | 05:48 AM
Welcome to Jaguar Forums MKLJKLFOUR,
Old Nov 8, 2022 | 07:04 AM
Old Nov 8, 2022 | 08:38 AM
MKLJKLFOUR's Avatar
That is the one. What do you know greatly appreciate.
Old Nov 8, 2022 | 10:01 AM
Hello,
Old Nov 8, 2022 | 05:45 PM
There's several DTC's (error codes) listed in the Workshop Manual for the adaptive headlamps but it requires dealer level diagnostics to read them. The bad news is that other than tracing power or ground faults in the harness or connector, the recommended action for most of them is to clear the code(s) and re-test. If the code(s) persist - replace the headlamp!
Many weird electrical faults on modern Jaguars can result from a partially discharged or failing battery. Always a good plan to eliminate this before going on to more complex (and inevitably costly) possible causes.
MIGXK09
Jun 19, 2021 11:41 AM
Darren Lehan
Sep 27, 2018 09:48 AM
Dmac
Feb 25, 2017 08:47 AM
emaraszek
Oct 16, 2012 11:40 AM
Mar 16, 2006 03:10 PM
