Clock fast/slow Jag XJ8 Vanden Plas
Old May 21, 2013 | 10:11 PM
mishactoyn's Avatar
Cool Clock fast/slow Jag XJ8 Vanden Plas
I say nobody seems to answer this question. Original clock was perfect then began to run fast and sometime slow. I bout another one and it acts the same way, so there must be a system issue not the clock.
I have heard a hard reset might cure this (?)
Any ideas
Old May 22, 2013 | 04:27 AM
steveinfrance's Avatar
Welcome to this friendly Forum,
Your car's technical section is
XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum if you can't find the right time with a query then post your question there.
and there's a Regional one too
Western US - AK CA NV OR UT HI WA ID - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy your membership here.
Old May 22, 2013 | 05:13 AM
Welcome to the forum mishactoyn,
Of the many things a Hard Reset does affect, I would not expect it to have any influence on accuracy of the analogue clock.
Follow Steve's link to the X308 tech section for help, advice and information. The 'HOW TO' thread at the top there is a good place to start for info on regular issues.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Old May 22, 2013 | 05:46 AM
Old May 22, 2013 | 02:17 PM
plums's Avatar
At one time analog electric car clocks were built with self adjusting regulators.
Repeated adjustments forward would cause the regulator to shift faster and vice versa.
On that type of clock, habitually over running the adjustment and then reversing will have the effect of negating the self adjusting regulator mechanism.
Old May 26, 2013 | 08:48 PM
Welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos,
use the search facility etc, can be found here within the following link Helpful_information
Old May 27, 2013 | 03:24 PM
mishactoyn's Avatar
understood, I have done that too much. I hsve now left it alone for a few days, and it seems to have settled down. I will tell you later if it wored for me.
Old Jul 10, 2013 | 08:19 PM
mishactoyn's Avatar
Thanks, I kept fiddling with it and finally it did come right.
Old Jul 11, 2013 | 06:49 AM
welcome to the forum!!
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rick Michael
Sep 6, 2015 06:53 PM
edtexas
Sep 5, 2015 10:49 AM
