Considering purchasing a 1998 XJR
Old Jun 27, 2023 | 11:09 AM
luke.mitchell's Avatar
Default Considering purchasing a 1998 XJR
Hi, I’ve just stumbled upon this community and was wondering if anyone could give me some advice. I’ve found a 98 Jag XJR for sale near me for 2000 dollars and I’m rather interested in buying it. Im a little bit wary however due to the rather low price, with the only major issue known is there being fuel pumps that need to be replaced. I’ve watched a video on how to do so and am fairly confident I can complete said task with the help of a mechanically minded friend. Is there anything else I need to worry about that’s the reason behind the 2k price tag? Thanks so much!
P.S. Mileage is 156k, it will likely need a coat of paint, interior is nearly flawless.
Old Jun 27, 2023 | 12:57 PM
Welcome to the forums Luke,
The three weaknesses on the early XK8 are:
1. Engine: plastic tensioners can fail destroying the engine. At 156K miles it's likely these have been replaced with later metal ones but never make assumptions!
2. Cooling System: lot of plastic components which can fail with age. Check for evidence of replacement parts and any signs of leaks.
3. Transmission: Jaguar don't include fluid and filter changes in the maintenance schedules but doing this at around 70K mile interavls greatly increases unit life. Rebuild is expensive.
Painting a Jaguar to original factory standard is expensive which could account for the apparently low asking price.
A well maintained Jaguar is a pleasure to own and drive but a neglected example can be a serious money pit. The golden rule is - if in doubt, walk away.
Follow this link https://www.jaguarforums.com/forum/xk-xkr-x150-33/ to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Northeast Region forum by following this link https://www.jaguarforums.com/forum/us-northeast-35/ to find other members in your region.
Enjoy the forums.
Old Jun 27, 2023 | 06:05 PM
Thanks for the advice! The cooling systems and transmission are fine according to the owner, though he does not currently know if the tensioners were ever redone as he is the second owner. I’m hoping to at some point attempt to schedule a viewing of the car where I’ll see if I can determine whether or not the tensioners are factory. I’ll keep the forum posted as I gather funds and hopefully purchase the car.
Old Jun 27, 2023 | 06:41 PM
Welcome to Jaguar Forums Luke,
Old Jun 27, 2023 | 08:54 PM
Welcome to the Forums.
Old Jun 27, 2023 | 11:14 PM
Daf11e's Avatar
Welcome aboard Luke.
Old Jun 28, 2023 | 06:37 AM
Old Jun 28, 2023 | 08:53 AM
Hello, Luke,
I wish you well in your investigation of this XJR.
Old Jun 28, 2023 | 09:58 AM
Originally Posted by luke.mitchell
..... he does not currently know if the tensioners were ever redone as he is the second owner. .....
Luke,
The cam covers have to be removed to check the tensioners and an owner is likely to be reluctant to allow this amount of dismantling. Discussion on the forum is generally of the opinion that if a vendor can't absolutely prove they've been changed, assume they haven't and factor this into the price negotiation.
Old Jun 28, 2023 | 12:04 PM
Originally Posted by GGG
Luke,
Good point. Supposedly the previous owner took meticulous care of the car and they haven’t broken yet so I’m hoping they’ve been replaced.
Luke
Old Jun 28, 2023 | 01:22 PM
At 156K you are very likely to be right about that ...... but failure is an engine wrecker.
Jagustar
Sep 1, 2020 02:07 AM
k-man
Sep 12, 2015 08:45 AM
laurent442
Nov 30, 2013 08:26 AM
Usdm-sti-ftw
Dec 14, 2009 06:40 PM
jameshymel
Jun 23, 2008 01:37 PM
