Flash electrical?
Old Sep 27, 2020 | 04:24 PM
Stephen Poulter's Avatar
Default Flash electrical?
My electrical Parking brake quit working, and it beeps all the time...anybody know can I go anywhere else besides the dealer to get this fixed?
Old Sep 27, 2020 | 05:21 PM
NBCat's Avatar
It would be very helpful to know the vehicle model, MY, kilometres/miles and conditions the vehicle is operated under.
What is the battery voltage across the terminals with the ignition in the OFF position when checked with a voltmeter?
Old Sep 27, 2020 | 05:26 PM
Daf11e's Avatar
Welcome aboard Stephen.
Old Sep 27, 2020 | 05:27 PM
2007 xj8-L .. I use the emergency brake at Redline to slip it into neutral and pull the emergency brake on because I have a bad leg. Then it just suddenly stopped working.
Old Sep 27, 2020 | 05:49 PM
NBCat's Avatar
Old Sep 27, 2020 | 05:54 PM
Welcome to the forums Stephen,
Follow this link https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X350 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Western Region forum by following this link https://www.jaguarforums.com/forum/us-western-38/ to find other members in your region.
I've added vehicle details to your Signature to help others to give relevant advice. If you want to change these, go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Enjoy the forums.
Old Sep 27, 2020 | 09:18 PM
Welcome to the Forums.
Old Sep 28, 2020 | 12:13 AM
o1xjr's Avatar
Welcome to the forums.
Old Sep 28, 2020 | 06:45 AM
Welcome to Jaguar Forums Stephen,
Old Sep 28, 2020 | 09:15 AM
Hello. Stephen,
Old Sep 28, 2020 | 11:54 AM
S-Type Owner's Avatar
Welcome... Centerville, Ohio or Centerville, Utah...?
"I use the emergency brake at Redline to slip it into neutral and pull the emergency brake on because I have a bad leg. Then it just suddenly stopped working" You apply the EPB at "redline"...?
I understand the bad leg part of the equation, but I am not sure the electronic parking brake was designed or intended for regular use in this manner. For most users it gets applied after the transmission is in "park" and the pawl is engaged inside of the transmission as a back-up.
Old Sep 28, 2020 | 02:39 PM
falderfer
E type ( XK-E )
May 21, 2021 11:53 AM
New jag driver
Apr 25, 2020 08:21 AM
malx
Nov 24, 2015 12:29 PM
