Flex Plate and Ring Gear replacement 2007 Jag X type
Old Oct 17, 2021 | 05:34 PM
Edward's Avatar
Smile Flex Plate and Ring Gear replacement 2007 Jag X type
I have been told that my ring gear is worn on my flexplate which shows up when you attempt to start the vehicle the starter engages the flywheel but does not turn the motor over. After several attempts the starter finally engages and the vehicle starts and runs fine. So my question is how much does it cost to replace that flexplate and ring gear assembly. The shop said it could take up to 3 days..........the vehicle has 123K miles and runs great looks great......so I am opting to repair it. Just want to know a ball park on the cost. I live in Tucson Arizona
Old Oct 17, 2021 | 07:28 PM
Hello, Edward,
You should get a firm estimate from the shop doing the work. Then you'll at least have a starting place.
However, if you decide to let them change the ring gear, be sure they change the starter too unless it's a relatively new unit, so that you'll have a new pinion meshing with the new ring gear.
Old Oct 18, 2021 | 01:38 AM
Daf11e's Avatar
Welcome aboard Edward.
Old Oct 18, 2021 | 02:20 AM
Welcome to the forums Edward,
Good advice from Elinor. It is going to be expensive and you need a fixed quote in advance. Once it's in pieces, the shop has you over a barrel. The phrase "up to 3 days" suggests to me they haven't done this before.
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Southwest Region forum by following this link https://www.jaguarforums.com/forum/us-southwest-37/ to find other members in your region.
Enjoy the forums.
Old Oct 18, 2021 | 03:33 AM
o1xjr's Avatar
Welcome to the forums.
Old Oct 18, 2021 | 04:30 AM
Welcome to the Forums.
Old Oct 18, 2021 | 06:53 AM
Welcome to Jaguar Forums Edward,
Old Oct 18, 2021 | 09:44 AM
welcome to the forum - enjoy!!!!
Old Apr 3, 2023 | 07:35 AM
BeverlyD's Avatar
Default "How to Replace the Flex Plate and Ring Gear on a 2007 Jaguar X-Type
The flex plate and ring gear are both components of the transmission system in a vehicle. The flex plate is a circular plate that connects the engine to the torque converter, while the ring gear is a gear that is attached to the flex plate and engages with the starter motor to crank the engine.
To replace the flex plate and ring gear on a 2007 Jaguar X-Type, you will need to follow these general steps:
  1. Raise the vehicle using a jack and jack stands, and secure it in place.
  2. Disconnect the negative battery cable.
  3. Remove the transmission from the vehicle by following the manufacturer's instructions. This will likely involve removing the driveshaft, starter, and other components.
  4. Locate the flex plate and ring gear, which will be located on the back of the engine.
  5. Remove the bolts that attach the flex plate and ring gear to the engine.
  6. Remove the old flex plate and ring gear from the vehicle.
  7. Install the new flex plate and ring gear, making sure they are properly aligned with the engine.
  8. Tighten the bolts that attach the flex plate and ring gear to the engine.
  9. Reinstall the transmission and other components that were removed.
  10. Lower the vehicle and reconnect the negative battery cable.
It's important to note that this is a complex and involved process, and it may be best to consult with a professional mechanic who has experience working on Jaguar vehicles to ensure the job is done correctly and safely.
Old Apr 3, 2023 | 01:08 PM
Originally Posted by BeverlyD
..... it may be best to consult with a professional mechanic who has experience working on Jaguar vehicles to ensure the job is done correctly and safely.
Welcome to the forums BeverlyD,
I don't know how you found this Intro thread or chose to respond to it as it was posted in October 2021. The OP logged out six minutes after posting the question and has not been back in eighteen months since then!
Ric Gallaher
Jun 26, 2017 08:06 AM
wendelllambert
Mar 22, 2017 05:41 AM
Grom
Sep 7, 2016 07:20 PM
