fuel pressure problem 1994 xj12
Old Oct 18, 2014 | 12:03 PM
wifesxj12's Avatar
Default fuel pressure problem 1994 xj12
Hi, My wife has a 1994 Jaguar xj 12 that i am working on. The car was running and driving and we parked it. Sat outside for a year which did it no good.
Never again! Water in the tank, so i siphoned out the gas and put 5 gallons of fresh in along with bottle of sea foam. I also removed the fuel filter and unhook fuel lines on engine and blew out lines.
Installed new filter. Car wouldn't even try to start. Removed filter and had someone turn key forward while i watched for fuel pressure and barely a drip out of fuel line from tank.
Checked fuses. Removed tank and emptied fuel. Looks like two pumps inside. Plugged in wiring and turned key forward. Pump on passenger side activates, but drivers side doesn't.
Haven't pulled them yet to inspect anything. Looks like some rubber fuel hoses going back and forth. Does anyone know if both pumps should kick on or what i should check.
Called a jaguar dealer and their tech said he had no idea there was two pumps and basically had no advice at all. I read another thread and someone said the pumps themselves are in those white cylinder modules.
Any advice?
Old Oct 18, 2014 | 12:04 PM
Helpful_information
Old Oct 18, 2014 | 12:40 PM
Welcome to Jaguar Forums wifesxj12,
To get tech advice follow this link XJ40 - Jaguar Forums - Jaguar Enthusiasts Forum and take a look in the regional section also USA Mid West - IL IN IA MI MN MO OH WI - Jaguar Forums - Jaguar Enthusiasts Forum
Old Oct 18, 2014 | 01:19 PM
welcome to the forum - you will find a wealth of info and support here simply follow the links Norri has provided - enjoy!!!
Old Oct 18, 2014 | 02:00 PM
Welcome to the forum wifesxj12,
Follow Norri's link in post #3 to the XJ40 forum for help, advice and information.
Enjoy the forums.
Old Oct 19, 2014 | 05:52 AM
o1xjr's Avatar
toronadomike
Jan 22, 2026 10:13 PM
alpecsa
Sep 7, 2015 11:55 AM
philwarner
Sep 5, 2015 10:05 AM
d a
Sep 3, 2015 02:34 AM
