Hazard lights continuously working
Hi everyone 🤙
I'm coming with a problem which had become a really nightmare now,
I bought a Jaguar Xf 2012 model and after replacing the start/stop battery I left the service yard and when I got home I noticed that my hazard lights are flashing but I didn't press the hazard button at all that day, anyway I tried to switch them off from the button but nothing happened, also the brake light stays on together with it,
I have to remove the negative from battery overnight so the battery won't get flat , in the morning I reconnected the battery and the hazard lights start flashing as soon as I touched the negative on the battery. ( I have to mention there's no errors on dashboard and the car starts and drive perfectly, also everything else working in order)
I have checked all the fuses and relays possible front and back and also the fuses and relays under the glove box, I have checked all the plugs from all modules and clean them and spray them with contact spray, i also changed the buttons console but still nothing happens, I called the Jaguar center and I explained them my story and they said it might be a BCM failure ....now I'm asking for your help guys if anyone had this problem before ?? Any advice other than I mention will be greatfully appreciated!
in my opinion I try to believe that not the BCM is the problem but who knows ..really weird if so because only hazard lights and stop light stays on, everything else is perfect.
Welcome to the forums Cip,
I've moved your other post of this question to X250 forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...orking-270804/
Follow this link https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the main X250 forum for help, advice and information. You can also use the Europe Region forum by following this link https://www.jaguarforums.com/forum/europe-42/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Welcome to Jaguar Forums Cip,
oo zone
Oct 8, 2021 02:33 PM
