Hello,
18 months ago we purchased through craigslist a 1998 Jag XJ8 in amazing condition . It had 98,000 miles on it and had been sitting in a garage for years - in super-fab condition. We drove it and drove it and it purred like a cat. We recently changed the oil, (3 months ago) and then had it smogged (Cali law). It passed smog no problem. Not a single problem! Then, today, it died, apparently something blew up inside the engine and one piston has a hole in it now.
How could this have happened?????
What's to do now!!!!!!
It is hard to believe we went from styling and happy in our Jag, to the owners of a worthless, dead car. Is there any hope?
Dena
Dena
o1xjr
close
- Join DateJan 2014
- LocationDelaneys Creek,Qld. Australia
Liked:6,340 Times in 4,380 Posts
Welcome to the forums.
Daf11e
close
- Join DateMar 2015
- LocationDural, Northwest Sydney. Australia.
Liked:4,709 Times in 3,258 Posts
Welcome aboard Dena
Grant Francis
close
- Join DateFeb 2010
- LocationAdelaide Stralia
Liked:11,280 Times in 7,448 Posts
Welcome.
Sounds like the well documented timing chain upgrade has NOT been done.
Sad, agreed.
The USA may have s/hand etc engines floating around.
Good luck.
Sad, agreed.
Good luck.
close
- Join DateDec 2011
- LocationDurham, UK
Liked:17,010 Times in 12,223 Posts
Welcome to the forum Dena,
Good to have you with us at Jaguar forums. Sorry to hear about the engine. It sounds like it's been the regular failed plastic timing chain tensioner issue.
Follow this link XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Western Region forum by following this link https://www.jaguarforums.com/forum/us-western-38/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Norri
close
- Join DateOct 2007
- LocationPHX some of the time
Liked:6,652 Times in 5,788 Posts
Welcome to Jaguar Forums Dena,
sklimii
close
- Join DateApr 2012
- LocationSummerville, South Carolina
Liked:4,707 Times in 4,011 Posts
LnrB
close
- Join DateMar 2014
- LocationTehama County, California, USA
Liked:10,312 Times in 5,914 Posts
Hello, Dena,
I'm sorry your Jag died.
Guido's Auto Precision in Chico may be able to help you.
(530) 891-8313 is the number.
NBCat
close
- Join DateJan 2012
- LocationNewport Beach, California
Liked:2,983 Times in 2,028 Posts
It's much quicker and less costly to find a used AJ26 from a breakers yard and have it installed.
If the primary and secondary timing chains, guides and tensioners had not been upgraded to the latest version, catastrophic engine failure is the result.
Well, we found a mechanic who found us a used engine for $1200 and is going to put it in for us for less than that in labor. Should we make sure that the timing chain tensioners are upgraded before they put it in?
Thnaks
Thnaks
close
- Join DateDec 2011
YES - if I'd had an engine failure, I'd certainly spend a little extra to make sure the replacement wasn't going to go the same way.
There's two things cause serious engine trouble with the Jaguar V8:
1. early plastic tensioners - you know all about that now!
2. overheating
Early water pumps had a plastic impeller that was prone to the vanes breaking up which is also worth a check. There's two cooling hoses that run between the 'V' of the cylinder heads known as the 'valley hoses'. It's normally a lengthy job to replace these but they are easily checked and replaced if necessary during an engine swap.
2. overheating
