jag owner, with questions
Old Dec 23, 2011 | 10:25 AM
1blondgal's Avatar
Default jag owner, with questions
Hi I have 2001 jag s type v8, beautiful car! I love it.
Just changed battery, and now it won't start..
Electrical works fine, have gas, just won't turn over.
Not sure of what to do.
I love my car.. just want to use it.
Someone please help.
Had mechanic friend look at it. (gmac mechanic)
he doesn't know what it could be.. thought you might know..
Please help.
Old Dec 23, 2011 | 11:08 AM
Hey there blondgal and welcome aboard the forum, great to have you with us here at JF
The S type gurus will help you out for sure and get you goin again
Old Dec 23, 2011 | 04:56 PM
Welcome to the forum,
I see you posted in the S section so you should get some help.
Old Dec 24, 2011 | 02:31 AM
Languid's Avatar
Default Won't Start
1blondegal,
I recently had this problem with my Range Rover, backed it out onto the street to do some work on a Jeep (now there is a 'dray'), half an hour later wouldn't start when I went to bring it back in. Firstly, when you turn the key to the start position, do the dash lights dim or not. If they do, check connections between the battery and the starter motor, including carefully check earth connections.
If they don't, check the wiring circuitry between the ignition switch and the starter solenoid, in particular the connector to the solenoid itself. I had to pull mine off, clean it, and refit it. Took me all of two minutes, and solved the problem. Since you don't appear to be all that 'mechanical', (I did read about the spark & the petrol), I'd suggest that you 'show a little leg' and get your friend to have a look at the light wire with a spade terminal which plugs onto the back of the solenoid which is bolted onto the starter motor.
The basics are, if there is no 'dimming' of the dash indication (warning) lights, then there is no load being placed on the battery. Starting an engine draws one hell of a lot of current (like 400 to 600 amps), therefore any low current draw lights like globes or similar will dim due to the voltage drop incurred.
The other thing to chech is that the gear selector is properly seated in park or neutral. Also, (and I'm not sure with your model) be aware that there can be acorrelatrion between the footbrake being applied and selecting out of park. If someone has used force to try to do this, it is possible to damage the adjustment which can result in the park position not enabling the circuit to complete to the starter motor. This is fairly unlikely, but I've heard of stranger things.
cheers,
Languid
danpop
Sep 3, 2015 08:06 PM
jagy4321
Sep 3, 2015 07:56 PM
kesslari
Aug 31, 2015 10:20 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Terencex
Aug 26, 2015 08:47 AM
