Jaguar xk8 2001
Old May 9, 2023 | 08:25 PM
Litcoreyy's Avatar
Default Jaguar xk8 2001
Hey I’m a younger guy learning about cars I have a 01 Jaguar xk8 and had code p1722 it went into limp mode and then I gotten the transmission swapped out and it still has the code p1722 it drives smooth shifts fine I just don’t know why I have the code the check engine light is off to
Old May 10, 2023 | 02:39 AM
Welcome to the forums Litcoreyy,
Swapping the transmission was a bit drastic and probably a lot $$$!
I'm not sure from your post whether the vehicle is still in limp mode after the swap or it's just the P1722 code that's persistent. If it's the latter, clear the code and see if it comes back. Here's the Jaguar list decode for P1722. I've included P0721 as the P1722 'possible causes' cross references this even though the code may not be set.
This gives you an idea of where to start investigating other possible causes and you should take the discussion to the XK8/XKR forum where more other members with the same model will see it.
Follow this link https://www.jaguarforums.com/forum/xk8-xkr-x100-17/ to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Southwest Region forum by following this link https://www.jaguarforums.com/forum/us-southwest-37/ to find other members in your region.
Enjoy the forums.
Old May 10, 2023 | 04:10 AM
Welcome to the Forums.
Old May 10, 2023 | 06:28 AM
Old May 10, 2023 | 09:29 AM
Hello,
Old May 10, 2023 | 03:34 PM
Welcome to Jaguar Forums Litcoreyy,
Old May 10, 2023 | 06:59 PM
Daf11e's Avatar
Welcome aboard.
Mitro
Sep 13, 2021 01:09 PM
Jude Kerr
Jun 23, 2018 06:36 AM
deelli
Dec 19, 2016 10:56 PM
reelpirate
Jun 23, 2010 09:58 AM
