misfires when cold
Old Feb 23, 2013 | 02:25 AM
faiswish's Avatar
Default misfires when cold
Jaguar s type v6 3.0l 2004 I'm going to install new universal catalytic converter will it turn check engine off?
Old Feb 23, 2013 | 02:54 AM
steveinfrance's Avatar
Welcome to this friendly Forum.
I see you've found your technical section, you will need to get an OBD code reader to check the problem. There's a huge thread here
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
There's a Regional section for Canada
Canada, Mexico, South America - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy your membership here.
Old Feb 23, 2013 | 03:03 AM
Welcome to the forum faiswish,
Follow Steve's advice about a Code Reader. An essential piece of equipment to help maintain your S-Type.
If you're new to this model, the 'HOW TO' thread at the top of the S-Type tech section is a good place to start for info on regular issues.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Old Feb 23, 2013 | 11:37 AM
Old Feb 23, 2013 | 06:14 PM
faiswish's Avatar
Jaguar s type 3.0l v6. I get p0420 & p0430 code I change both side all 4 brand new o2 sensors, still same, I took old catalytic convert out they were bad and pluged.
Can I install universal cc but I have to weld o2 sensor cuppler on it on same spot, will it shut my check engine light off?
Old Feb 24, 2013 | 04:50 AM
After you've fitted the new sensors, the stored P0420 and P0430 codes and the CEL won't disappear by themselves. You need to have them cleared with a ScanTool.
Old Feb 24, 2013 | 11:56 AM
faiswish's Avatar
I did clear 3 times and it came on after 5 minutes.
Old Feb 24, 2013 | 01:37 PM
The codes are resetting on the next diagnostic cycle which means the fault hasn't been cleared by fitting new sensors.
The possible causes on P0420 and P0430 are:
1. HO2 Sensor disconnected
2. HO2 Sensor to ECM wiring fault
3. HO2 Sensor heater to ECM wiring fault
4. HO2 Sensor heater failure
5. Upstream HO2 Sensor failure
6. Downstream HO2 Sensor failure
7. Catalyst failure
You've eliminated 5 and 6 with new sensors and should also have eliminated 4.
Before assuming catalyst failure and throwing $$$'s at it, items 1, 2 and 3 should be checked first.
I suggest you post the question in S-Type tech section for advice from members with the same model.
Old Feb 24, 2013 | 02:06 PM
faiswish's Avatar
I truer almost everything My JAG has lots of klometer on it 280000k Now remove the old catalytic converts and open they looks bad and melted inside there is no way I can them back but my question is can I install universal cat con on it an will it shut CEL off?
Old Feb 24, 2013 | 05:19 PM
There's a risk in using anything other than Jaguar catalytic converters.
If universal ones can be used successfully, the members on the S-Type tech section with the same model as you will know. Post the question about universal catalytic converters in the tech section:
S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum
You should get advice there on suitable alternatives.
Old Feb 26, 2013 | 08:15 PM
Hi & welcome aboard Jaguarforums ....... good to have you here with us
Any useful site information you may need such as how to post pictures, edit signatures, add videos,
use the search facility etc, can be found here within the following link Helpful_information
aode06
Jul 28, 2023 02:26 PM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
