Multiple warning lights
Old Aug 25, 2014 | 08:15 PM
Jayboy's Avatar
Default Multiple warning lights
New here. ABS light came on and went off a couple of times. Then coming home on interstate and car just stopped running. No warning lights. I pulled over and tried to restart. When I turned the key on I received electrical fault, stability control failure, suspension fault, check engine, ABS. Wouldn't start. Waited 15 minutes and it started. Drove 5 minutes and went dead again. Waited 15 minutes and it started. Parked it at home but couldn't get it started again. I cleaned throttle body. Still no start. I tried several times over the last few days to no avail. Anytime I tried I got all same lights. I tried again just now and noticed only stability, check engine, ABS were on but it started and ran at 2000 rpm for about 5 minutes then stopped and a lights on again. Will not start now. It could be a coincidence but I pushed ACS button and it it went dead and will not start..Could it have something to do with the heat of the engine?
lights. lights. I tried again today several time
Old Aug 25, 2014 | 08:53 PM
Welcome to Jaguar Forums Jayboy,
Best to head over to the tech section and ask there XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum there is also a regional section for your area to check out USA Lower Atlantic - NC SC FL GA - Jaguar Forums - Jaguar Enthusiasts Forum
Old Aug 25, 2014 | 09:21 PM
o1xjr's Avatar
Welcome to the forum
Old Aug 25, 2014 | 09:37 PM
I'm sorry you're having such trouble with your car. You'll find lots of help and advice for your problems among these forums.
Welcome from ElinorB.
Old Aug 26, 2014 | 02:10 AM
Welcome to the forum Jayboy,
You need to get a code reader on the vehicle to find out what's going on.
Follow Norri's link in post #2 to the X308 forum for help, advice and information.
Enjoy the forums.
Old Aug 26, 2014 | 06:10 AM
Welcome to the forum - you will find plenty of info and support here simply follow the links Norri has provided - enjoy!!!
Old Aug 28, 2014 | 11:50 AM
Helpful_information
99xk8guy
May 28, 2024 09:36 PM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
simo5555
Sep 9, 2015 06:22 AM
edtexas
Sep 4, 2015 08:20 PM
