Overdrive solutions
Old May 29, 2025 | 05:03 PM
Henry Shed's Avatar
Default Overdrive solutions
I've just had a very expensive rebuild done on my MK8 DG250 auto, but one issue (not a fault with the gearbox) still bugs me, as it has for the 35 years I've owned it. This is to do with the high revs while cruising. I know what's being shown is to spec, but it is irksome, perticularly on a long journey. At 60mph it indicates over 3000rpm, whereas my more modern XJL indicates around 1300rpm at the same speed. I don't expect the MK8 to do the same as the XJL, but I suspect the constant higher revs must have an impact on fuel consumption and engine wear. Has anyone come up with a work-around to help with this? I thought of changing the diff ratio, but this affects all gears, when I only need to modify top gear. Can an overdrive be put on the back of an auto box? Any other ideas? Thanks
Old May 29, 2025 | 05:12 PM
Daf11e's Avatar
Welcome aboard Henry, for information on your MK8 just ask questions here.. https://www.jaguarforums.com/forum/mark-v-x-420g-58/
Old May 29, 2025 | 08:56 PM
Welcome to the Forums.
Old May 30, 2025 | 08:06 AM
Welcome to Jaguar Forums Henry,
Old May 30, 2025 | 09:20 AM
Hello, Henry,
Old May 31, 2025 | 08:18 AM
JB-Miami
Aug 25, 2024 06:04 PM
Norman C-C
May 11, 2024 09:13 AM
Benjibooji
Jul 18, 2021 08:14 AM
Donaldmaclean81
Oct 16, 2019 06:56 AM
JNB
Jan 15, 2013 08:44 PM
