Shakes 1990 xjs
Old Sep 8, 2013 | 05:47 PM
Donaldmolsen's Avatar
Default Shakes 1990 xjs
I have a 90 xjs covt only 38k miles, new tires and rims but still shakes a lot when you reach 58 get better after 65. While expect some cowl shake this is excessive any suggestions?
Old Sep 8, 2013 | 05:59 PM
Welcome to the forum Donaldmolsen,
Good to have you here with us at Jaguar forums.
Follow this link XJS - Jaguar Forums - Jaguar Enthusiasts Forum to the XJS section for help, advice and information.
You can also visit the US Lower Atlantic Region section by following this link https://www.jaguarforums.com/forum/lower-atlantic-nc-sc-fl-ga-66/
Old Sep 8, 2013 | 06:01 PM
Doug's Avatar
"...still shakes..."?
From this can we presume that the shaking was also present with the previous tires and wheels, and is unchanged with new tires and wheels? If so we can probably rule out a tire/wheel problem, as two different sets of tires and wheels wouldn't likely have the exact same fault.
Is this something you feel thru the steering wheel? Or thru the body of the car? Or both?
If the shaking is primarily felt thru the steering wheel then you might have a problem with a loose/worn tie rod or other suspension part.
Is the shaking entirely road speed sensitive or will engine rpm change it? Try shifting to neutral or downshifting to a lower gear. If engine rpm doesn't change the shaking then we can rule out a few things.
Old Sep 8, 2013 | 06:49 PM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
If you need any further help with the site, please just ask any moderator, veteran member and we'll be glad to assist.
In the meantime, any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search
facility etc, can be found here within the following link
Helpful_information
See you in the forums....
Old Sep 9, 2013 | 05:06 AM
Default Thanks Doug
Doug the had the same problem with old tires and rims. Shakes are more body than steering wheels and build to a max in the low 60's then get better. No issue with rmps's however strange every once in awhile when cold the car will rev itself when coasting. Mechanic told me cowl shake is normal with this car however this amount is not normal
Old Sep 9, 2013 | 05:52 AM
Welcome to the forum Donald,
Old Sep 9, 2013 | 06:35 AM
welcome to the forum
Old Sep 9, 2013 | 07:21 AM
Doug's Avatar
Ok.....
Shakes thru the body, not engine rpm sensitive, and not wheels/tires.
At this point I'd be suspicious of the U-Joints.
Old Sep 9, 2013 | 03:41 PM
Thanks, I'll take it to a different mechanic and have him fully check the suspension including the u joints
Old Sep 17, 2013 | 08:01 PM
Default Shakes
Hi Doug looks, like my Jag guy wants to install a OEM Jaguar Convertible Torsional Rigidity "X" Bracing System. He told me they were,used on 1992 and newer xjs's. Hope this will help nothing on the suspension was found to be out of
order
yoiyoi
Dec 19, 2023 12:51 AM
gold59
US Lower Atlantic
Sep 16, 2015 06:27 AM
alfred
E type ( XK-E )
Sep 14, 2015 08:38 AM
Havigdort
Sep 13, 2015 04:42 AM
JagLove86
Sep 6, 2015 10:36 PM
