X-Type losing power
Old Jul 11, 2013 | 05:09 PM
toakenspy's Avatar
Default X-Type losing power
Hi everyone.
This is my first time on these forums and my second Jaguar in my life. Had a 2001 XJ Sport 3.0L V6 for a few weeks then sold on. It's very nice to be here.
I now have a 2002 X-Type in white, lovely car. However, recently the car has been losing power when trying to accelerate no matter what type of ground I'm on. hill or flat it drives for approx 15 miles then starts to stutter, slow down and when pressing accelerator pedal there is very little power and have to pull over, turn off engine and then drive off again. Here's what I've tried so far;
Put Cataclean into the petrol tank (the power loss issues started after that)
Removed fuel filter blew through it, the fuel inside sprayed out the other end fine
Removed downstream O2 sensor on catalytic converter at front of car, drove round a few streets and the power still seemed very low on acceleration.
Sprayed round the air intake manifold area to see if there was an air leak, again the engine note never changed.
Cleaned throttle body, no change.
The other thing I should mention is, the EML comes on each day and the code is P0430 Catalyst Efficiency Below Threshold, I reset it and it takes a while til it appears again. There is another code P1000 which I believe to be a test cycle failure. Does anyone have any other ideas I could try? I'm thinking the spark plugs next?
Thanks.
Old Jul 11, 2013 | 05:36 PM
Welcome to the forum toakenspy,
Good to have you here with us at Jaguar forums.
P1000 = OnBoard Tests not completed since last memory clear. With a Jaguar, you will always see this one or P1111 (OnBoard Tests complete).
P0430 = Catalytic converter system efficiency below threshold (Bank 2). This indicates a problem with an HO2 Sensor.
Follow this link X-Type - Jaguar Forums - Jaguar Enthusiasts Forum to the X-Type section for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
You can also visit the UK Region section by following this link https://www.jaguarforums.com/forum/uk-68/ to find other members in this country.
Old Jul 11, 2013 | 05:38 PM
toakenspy's Avatar
Thanks Graham, I will take a look at the links provided.
Old Jul 12, 2013 | 07:32 AM
welcome to the forum and Jag family - hope you can get resolution to your issue - there is plenty of info and support here - enjoy!
Old Jul 12, 2013 | 09:27 AM
Old Jul 12, 2013 | 11:45 AM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link
Helpful_information
Old Jul 12, 2013 | 12:18 PM
toakenspy's Avatar
Thanks again.
Old Jul 24, 2013 | 02:02 PM
toakenspy's Avatar
Default Possibly Solved
Well here's an update folks. Took it to a garage who scanned the car for codes, LOADS. Cleared them all and took it for a drive to suspect clogged catalytic converter. Solution, get 2 bottles of Cataclean, put £10 of super unleaded (the good stuff) in the car and one bottle of Cataclean. Motorway driving for 30 mins or so to burn it through, worked a charm!! no more shuddering or power loss. I then put another £10 of super unleaded and the other bottle of Cataclean. Car drives much better now, think I will use super unleaded more often. Thanks to everyone who submitted their views and help on this.
Old Jul 24, 2013 | 02:11 PM
Originally Posted by toakenspy
Well here's an update folks. Took it to a garage who scanned the car for codes, LOADS. Cleared them all and took it for a drive to suspect clogged catalytic converter................
Good to hear the car is running well.
Did you take a note of the LOADS of codes? Many codes are triggered appear after a repeated fault on two drive cycles. Always helps to know if something is a completely new event or a recurrence.
Old Jul 25, 2013 | 03:50 AM
toakenspy's Avatar
Unfortunately not, it was the garage who scanned it and cleared it. The P0463 cat code no longer appears withthe EML either now so if I use super unleaded and a bottle of cataclean every couple of months then I'm sure it would help keep the catalytic converter clean.
Old Jul 25, 2013 | 03:54 AM
An 'Italian Tune Up' can give similar results - flat out for a few miles.
Unfortunately if you live anywhere near the 'safety' camera infested A9, this won't be an option!
rusty37
Sep 18, 2015 10:03 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
texaspete
Sep 10, 2015 08:34 AM
mrplow58
Sep 9, 2015 11:27 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
