Xjr sc 300 1996
Old Jan 28, 2019 | 01:09 AM
New Zealand Jag Enthusiast's Avatar
Default Xjr sc 300 1996
Check engine light coming on intermittently, but each time it comes on the revs drop right down and if accelerator is touched revs come back up for another few kilometres. It is getting worse and worse and less time between check engine light and revs dropping.
Have replaced ignition coils, spark plugs. Have checked injectors, all passed A1, checked fuel pressure - okay, but fuel consumption getting worse and plugs sooting up from 50 to 100 km so badly have to be cleaned. I have exchanged the ECU with another with same numbers, shows no difference - maf airflow also been changed to no apparent benefit, lambda's have changed, but don't help. This car has done about 180 thousand km and this problem came up about 4000 km ago. Have also changed fuel filter, fuel pumps, inside of petrol tank is perfectly clean.
Can somebody please help me with this because whenever I have looked up check engine light on the internet, none of them have the same symptoms of the rev counter dropping right down.
Hopefully I can get to drive my beautiful car again.
I am a jag mechanic but have not worked on jags since V12s
Desperate Dave
Old Jan 28, 2019 | 02:36 AM
Welcome to the forum Dave,
I've copied your post to X300 forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...1996-a-213317/
Follow this link https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/ to the main X300 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the New Zealand Region forum by following this link
https://www.jaguarforums.com/forum/new-zealand-97/ to find other members in your region.
Enjoy the forums.
Old Jan 28, 2019 | 02:40 AM
o1xjr's Avatar
Welcome to the forums Dave, I have added you to the NZ Roll Call thread.
https://www.jaguarforums.com/forum/n...9/#post2019520
Welcome to the Forums.
I suggest a re-ask in the X300 Tech Section, down the home page a tad, and also check the "stickies" at the top of that section.
Crank Angle sensor comes to mind,and mine died at 160000kms for no apparent reason.
You have tested/checked heaps, and that CAS is all that is left on my short list.
Old Jan 28, 2019 | 03:02 AM
Daf11e's Avatar
Welcome aboard Dave.
Old Jan 28, 2019 | 05:25 AM
Welcome to Jaguar Forums Dave,
Old Jan 28, 2019 | 09:32 AM
Hello, Dave,
Welcome to the forums form ElinorB.
SteveM
Sep 19, 2010 01:03 PM
joel
Feb 27, 2008 08:18 PM
Lucian
Feb 17, 2008 05:59 PM
