XJS V12 fire - avoided
Old Jul 10, 2013 | 02:43 AM
machinehead's Avatar
Default XJS V12 fire - avoided
Hello all, I just about commited suicide a 1/2 hour ago when I re-installed the AAV valve on my V12 and started the engine... I saw fluid spurting out and thought that the water seal for the AAV hadn't sealed properly... I got out of the cockpit (cigarette in hand) and looked to see if the leak was coming from the AAV. I noticed a stream of fluid in the "V" and then realised #A4 EFI hose had split wide open. I shut the engine off and got out of the garage. After I extinguished my cigarette, I went back in and saw that a "lake" of gas had been pumped onto the garage floor (in ~30 seconds) on the passenger side. I'm letting the gas evaporate now. I don't have any spill containment, but it is drying up (evaporating) thank goodness. It was a miracle that the engine did not start on fire. I know these EFI hoses need to be replaced every 5 years at most, but I just got the car and the hoses were supple; I figured they would harden and crack before they leaked. NOT THE CASE. About a gallon and a half of gas on the floor in 30 seconds. Yikes. These things are dangerous. But I'm hooked.
Old Jul 10, 2013 | 03:01 AM
Stuart Beattie's Avatar
Ouch Machinehead,
They say that a lit cigarette won't ignite gas, but hey I'll leave that test to someone else!
You were lucky to notice something was up and it could have been VERY DIFFERENT if you had not cut the ignition.
Enjoy your quest but please...... Stay Lucky
Old Jul 10, 2013 | 05:58 AM
Welcome to the forum Machinehead,
A lucky escape.
Those V 12s seem to like catching fire,you'll find your fellow owners in the tech section XJS - Jaguar Forums - Jaguar Enthusiasts Forum and try and check your regional section also North East US - ME NH VT MA RI CT NJ NY PA - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jul 10, 2013 | 08:06 AM
That was a close call.
Follow Norri's link to the XJS section for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues. If you post your list of codes in the X-Type section, you'll get advice on causes and fixes.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Old Jul 11, 2013 | 06:26 AM
welcome to the forum - close call - quick thinking to cut the engine off!! Plenty of info and support here - enjoy the forum and the Jag
Old Jul 12, 2013 | 12:40 PM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link
Helpful_information
Rivguy
Dec 4, 2020 07:55 AM
Daim
Nov 28, 2016 09:28 AM
DrTripp
Sep 14, 2015 07:58 PM
1100me
Sep 7, 2015 06:26 AM
d a
Sep 3, 2015 02:34 AM
