yorkist
Old Nov 20, 2018 | 09:40 AM
Yorkist's Avatar
Question yorkist
My XK8 convertible from 2003 is my pride & joy but showing a few electrical annoying tricks.
1 Pax seat headrest motor keeps cutting in & out for no apparent reason
2 Wing mirrors no longer adjust.
3 Driver window inches down each time the outside door handle is operated but does not return up.
4 Steering wheel up/down position often needs resetting.
5 " Driver intervene " message sometimes shows when not in cruise control.
Any comments please.
Old Nov 20, 2018 | 03:23 PM
Hello,
Someone will be along shortly to direct you to our Xk8-XKR section where members who drive the same car as you can help you fix all those little annoyances.
Old Nov 20, 2018 | 05:11 PM
Welcome to the forum Yorkist,
The window auto drop/lift losing it's set positions is a classic symptom of a failing battery. Check and eliminate this before troubleshooting other electrical issues.
Follow this link
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/ to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the UK & Eire Region forum by following this link
https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Nov 20, 2018 | 05:53 PM
Welcome.
Yep, I agree with Graham. I read that list and BATTERY sprang off the page.
Good luck.
Old Nov 20, 2018 | 07:10 PM
Daf11e's Avatar
Welcome aboard.
Old Nov 21, 2018 | 06:59 AM
Old Nov 21, 2018 | 07:56 AM
Welcome to Jaguar Forums Yorkist,
Old Nov 22, 2018 | 02:51 AM
o1xjr's Avatar
Welcome to the forums.
Old Dec 1, 2018 | 06:36 AM
Yorkist's Avatar
Follow this link
Enjoy the forums.
Thanks very much. Indeed the battery has needed charging after each occasional outing which I was thinking may be due to some unseen drainage when parked.
Old Dec 3, 2018 | 01:57 PM
To put it into "sleep mode" (thus reducing drain on the battery by shutting down all but essential systems), the ignition key should be removed and the vehicle locked. Easy to forget this when the car is in a secure garage.
Many members use a CTEK charger to keep the battery in peak condition on a Jaguar which isn't used regularly.
