Fail Safe Engine Mode
Old Sep 22, 2019 | 05:56 PM
Rory Bremner's Avatar
Default Fail Safe Engine Mode
Hi folks,
I have an 02 XK-R that has been sitting for the winter months. Yesterday, I had to jump start the car (I know, I should have disconnected the battery) and the Fail Safe Engine Mode has appeared on the dash, with Cruise Control function not working, Faulty Part Fitted. Very confusing as no such part has been exchanged or fitted. Any suggestions and recommendations for a good mechanic in the Wellington area?
Kind regards,
Rory
Old Sep 29, 2019 | 05:22 AM
o1xjr's Avatar
Welcome to the forums Rory, please post an intro in the new member area when time allows.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Jan 1, 2020 | 01:10 AM
SilverXJX356's Avatar
Originally Posted by Rory Bremner
Hi folks,
Kind regards,
Rory
Hi Rory
The reduced power, and cruise control out, go hand in hand.
It could be an ERV unit failed, but you will probably need an AutoLogic diagnostic unit on the car to check it out!
Try either John at Wellington European (formerly Toyshop) or Phil at Advance Auto Electrical in Petone (they have guys that are both A Grade mechanics and Auto Electricians).
Neil
Old Jan 1, 2020 | 03:30 AM
If it was OK when you parked it up for the Winter, the chances are high that the spurious faults are due to a partially discharged or failing battery. Worth a recharge/replacement first before looking for more esoteric (a.k.a. expensive) possible causes.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jul 27, 2020 | 04:35 PM
Chris Ryan's Avatar
I have a 1998 XJ8L.Parked for the winter,when I tried to start her this spring I got FAIL SAFE ENGINE MODE reading on the dash.She won't start. Checked all fuses and disconnected the battery a number of times.HELP. I'm in Newfoundland Canada.
Old Jul 28, 2020 | 02:03 AM
Chris,
Only New Zealand members are likely to see your question here. If you had posted in the Model forum, members across the World would see it. Region forum is the place for geographically relevant questions and Model forum for technical questions.
See how it goes here and send me a PM if you want it moved.
EZDriver
Aug 29, 2019 08:21 PM
joec
Dec 22, 2013 08:22 AM
stevehill
Oct 26, 2012 10:01 PM
djsomebody
Jul 18, 2011 08:16 PM
