Other Jaguar Models / Concepts / Replicas Do you have a Jaguar model not listed above? This is the place to talk about it!
Jaguar Kougar
Old Jun 24, 2012 | 07:16 PM
bwilson1's Avatar
Default Jaguar Kougar
Does anyone have any knowledge / Experience with these? I believe they were build on an jag mk2 chassis...Anyways rebuilding the calipers for a friend which should be an adventurous task given the inboard brakes.
Old Jun 24, 2012 | 07:42 PM
avt007's Avatar
Never heard of them. Interesting though! The wheels look a tad large for the car, but pretty cool overall.
Old Jun 25, 2012 | 03:42 PM
SCMike's Avatar
I think that Kougar might still be in operation:
Home of the Kougar Classic Car Range - Kougar Sports - Kougar Monza - kouger-cars.com
In any case, the Kougar was not built on any Jaguar chassis - in the classic Brit kit car idiom, a purpose-built tube frame formed the Kougar's chassis. Then a defunct Jaguar saloon was used as the donor for the Kougar's mechanical bits - Mk 2 and S-Types (the classic one) were used as typical donors. Even a couple with a V12. In your case, since you have the in-board disk brakes, it sounds like your car is based on the 3.4 (more likely than the 3.8) S-Type. In that case, it must have the IRS rather than the Mk 2's solid axle rear end. So it is all just standard S-Type brake parts, not hard to find. Then just drop out the IRS as a unit for ease of access to all the bits.
Old Jun 25, 2012 | 06:12 PM
bwilson1's Avatar
Thanks SCMike that is exactly the type of info I needed!
Old Jun 25, 2012 | 07:21 PM
SCMike's Avatar
If you want to see what a ridiculously expensive specimen looks like, check this out:
1965 Kougar 3.8S Jaguar Special
Happy drooling!
Old Jul 1, 2012 | 11:57 AM
Cybersib's Avatar
Default Jaguar Mark V C
Sorry, wrong post area
Old Jul 1, 2012 | 12:01 PM
Cybersib's Avatar
Beautiful car!
Old Jul 10, 2013 | 11:25 PM
Bad Cattitude's Avatar
I see those pop up on eBay every now and again.
Old Feb 24, 2014 | 05:40 AM
kougarman38's Avatar
Default Kougar front brakes
Hi, most Kougar front brakes were from 'S' types, mine are from a 1967 S type! Very effective!
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
