Have a look at these
There's a sticky on posting pictures
https://www.jaguarforums.com/forum/j...pictures-2418/
if that helps.
if that helps.
if that helps.
if that helps.
Thanks for the link. I have a Webshot account which I use for all picture posting I also have a Photobucket site for my architectural work. The problem I have is that I wanted to post a link to an album of Max Power Photographs we completed in 2005 which has had 46000 visits. Not sure how to post a link. Saves posting a lot on the site and if people wish to view they can then acces the site. I will try again and see what happens.
Try this one:
http://community.webshots.com/user/m...host=community
If some kind person can access my albums I would be interested to know if the locked ones can be opened not a problem as there is nothing on there thast I would want to hide anyway but would like to know the security level.
Last edited by MacSTR; Aug 27, 2012 at 04:58 AM. Reason: added comment Link removed link added
Appears that I can copy and edit anything there. Here's an example of what I'd expect would be one of your 'locked' folders:
I've copied it from the site and flipped it 180 degrees to check whether it can be edited.
Haven't got a Webshots account so the regular save isn't an option but that doesn't stop the determined from copying once they have your link.
Just checked again the picture you posted was not locked and available for public viewing in the same was as others but where the ones that are locked they are not available for public viewing.
I may post the link again, what do you think? some very interesting pictures for those keen on aircraft and other things. As I did say the Max Power ones have had 40000 visits and 600 downloads.
If there's nothing personal on there then we're a right nosey bunch where photos are concerned - and Jim the Boss is as bad as any!
If it looks as if there's any chance of a baddie doing anything one of us will delete the link and let you know.
Either way you want to post them is going to be OK. Link to Online storage or copy pics as required from your PC into your posts.
