Coolant leaking, hose under supercharger.. YIKES
Old Jun 15, 2013 | 09:01 PM
justwant2drive's Avatar
Default Coolant leaking, hose under supercharger.. YIKES
Hey guys its been a while, my jag was running cool until a week ago when i noticed a large amount of coolant in my garage. After searching the forums when i couldnt locate the leak (res tank was replaced about a year ago). Anyways after adding coolant.........driving about 20 miles then getting a coolant level low warning, refilling, I took it in to my mechanic. At first he mentioned the hose under the supercharger, which after my searching on the forums I was afraid of. Anyways he found a spot under the supercharger with a puddle of coolant.
Long story short, i was trying to get a good idea if the price for the repair is cool......He's charging 1700 & will be replacing all the hoses under the supercharger (he said there was 4)....is $1700 a decent quote?
Old Jun 15, 2013 | 10:46 PM
Michael Star's Avatar
I'd be worried. There is only 1 (one) hose beneath the supercharger. There is a lot of work involved as you have to take a lot of stuff off to get to it (huge pain). I still think the price is high, knowing what I know now (I am a backyard mechanic) I could get it done in 6-8 hours from start to finish using hand tools. So feel free to stop by and give me $1700 and I will do it for you
Old is on the left, new style hose is on the right. Hose was $14 on Amazon
Attached Thumbnails Coolant leaking, hose under supercharger.. YIKES-img_20130601_165342.jpg
Old Jun 15, 2013 | 11:07 PM
TomSTR05's Avatar
Jag dealer gave me estimate $1500 for labor and parts.I took it to my Indy and he charged me $700 labor plus $400 for parts.He changed almost all hoses and gaskets.
Old Jun 16, 2013 | 12:09 AM
rasputin's Avatar
How many miles on your STR Tom? Best of luck, I think a member went through doing this himself on the forum, definitely worth a search to try an find that thread.
Old Jun 16, 2013 | 12:39 AM
TomSTR05's Avatar
It has 55K miles.... I already fixed it at my Indy shop around 3 months ago.
Old Jun 16, 2013 | 02:19 AM
Casper's Avatar
https://www.jaguarforums.com/forum/s...-repair-38911/
Old Jun 16, 2013 | 08:32 AM
clubairth1's Avatar
Community Influencer
Before jumping into this do a bit more troubleshooting? If you do change it consider changing the EGR valve to as it's right there and you most likely will have corroded bolts holding it on. The EGR tube is also known to rust out and leak. Don't want to go back into it again after fixing the hose! All your cost is in labor and gaskets.
As was posted above your mechanic is guessing? There is only one hose under the super charger.
Please pressure test the system when cold. The main symptom for the hose under the super charger leaking are red stains on the BACK of the engine. Puddles under the super charger can come from many sources since this is the low spot where all fluid will collect. Normally the hose under the super charger is a smaller leak and yours is pretty big but who knows the hose could have split?
I have had two coolant leaks on my 2005 STR and both of them put fluid under the supercharger. Both were $25 hoses that could be changed after removing the top tank. That's a whole lot cheaper!
Old Jun 16, 2013 | 12:35 PM
Robinb's Avatar
Sounds high, but depends on the hourly rate. Local Jag dealer here charges $145/hour. My Indy charges $108/hr, and the total bill to replace the darn $25 hose AND seal off the 2 pulsation dampers in the fuel rail (there was a smell of raw fuel in the cabin) was about $1450.
Old Jun 17, 2013 | 06:45 PM
Thanks for the responses. Yes there is 1 hose under the supercharger, but the mechanic suggested to change 3 more to save the headache in the future. Received a quote from another shop for $1500, they said to replace the 4 hoses as well.
Here's what I dont get though, both shops are charging me $200 for the hose, but the poster above said $14 on Amazon.....ummmmmmmm could I get a link?
Old Jun 17, 2013 | 07:09 PM
Amazon.com: URO Parts AJ89746 Throttle Body Coolant Return Hose: Automotive Amazon.com: URO Parts AJ89746 Throttle Body Coolant Return Hose: Automotive
Old Jun 18, 2013 | 12:45 PM
thanks Michael Star greatly appreciated & purchased!
now all i need is the other 3 hoses
Old Jun 18, 2013 | 01:02 PM
tbird6's Avatar
Please let us know about these additional hoses?
I don't see them?
Old Jul 19, 2013 | 01:07 PM
Received my car back...hoses were replaced & all was good
Yesterday morning, stopped to grab some coffee & the check engine light appeared with a message of "restricted performance"...FML
Just dropped $1560 to have the hoses replaced, couple of gaskets, etc
Stopped by the jag mechanic & he pulled codes P0400, P0171, & 1111
He tightened the gas cap, reset the codes & warning message was gone. So i felt like an *** thinking that it was somehow related to the gas cap.
Anyways, sure thing last night driving same warning message popped up!
Would love to have some information before seeing him this afternoon...with my search thus far, looks like "hose on passenger side of engine compartment causing vacuum leak"
Does that sound right?
Old Jul 19, 2013 | 02:23 PM
JagV8's Avatar
Look at the free codes PDF. In the stickies and also in JTIS.
P1111 is normal status. P0171 is running lean & P0400 is EGR flow fault - see the codes PDF for full info on each code as it shows known causes etc.
Bear in mind the EGR was off in the fix you had done, as I recall...
Old Jul 20, 2013 | 03:17 PM
Thanks. My mechanic changed the fuel filter & was sure that was the problem. Car was cool for a day, now the same issue, restricted performance. Hes pulling the codes now, seems to not think the problem has to do with anything hes fixed
Old Jul 21, 2013 | 12:58 AM
Code came back p1024. Dude is getting an air flow meter to check....could anyone advise if there's a possibility that the parts he removed & changed is the cause of the problem. It has to be right?
Old Jul 21, 2013 | 07:53 AM
JagV8's Avatar
P1024? What???
And those others have gone?
Old Jul 22, 2013 | 10:15 AM
Didnt get a chance to physically see the codes this time, just going on what he told me (the trust is quickly diminishing) .
Car is being checked tomorrow, mechanic needed an air flow meter
Was driving the car this morning & received the "usual" check engine light & restricted performance. About 10 minutes into the drive, a Transmission Fault appeared.
Old Jul 22, 2013 | 10:20 AM
I'd try cleaning the MAF first (you can pickup MAF cleaner from an autoparts store). Also, unplug it, check the pins for missing, corrosion, etc... Make sure it fully seats when you push it back on, it should click.
Old Jul 22, 2013 | 01:02 PM
JagV8's Avatar
Get your own code reader and DIY!
They're nearly free, now.
