"Fuel Pump System Failure"
Old Dec 26, 2011 | 06:44 PM
Bob Smith's Avatar
Default "Fuel Pump System Failure"
Hello,
Does anyone know what the "Fuel Pump System Failure" message means exactly (i.e., what really triggers it)?
I've seen this message twice now in the past 2 months. Each time the car has just been started after sitting overnight... the car starts right up and runs fine, the only thing noticeable is that the fuel tank gauge is not working (needle sitting far below empty) and the distance to empty stats are inoperable. After a couple minutes of driving, the message goes out and the fuel gauge and stats come back to life.
Any ideas?
The only work ever done in that area is that I had the fuel tank replaced at 40k miles under the recall. The car now has 93k on it.
Thanks for any help,
Bob
Old Dec 26, 2011 | 07:07 PM
joycesjag's Avatar
Bob the only thing that I can say is I have gotten into Joyces with no and I mean -zero- gas in the tank and the DIC stated fuel pump system failure. I dropped a few gallons in and ran it to the refill station.
Haven't had problems......Oh boy...
Old Dec 26, 2011 | 08:05 PM
Jon89's Avatar
Rick,
I finally managed to convince Jan not to run the gas tanks in either of her vehicles (the S-Type and the Lexus SUV) down below an eighth of a tank. I would prefer her filling up at a quarter tank remaining, but an eighth of a tank is better than showing up with the empty tank light illuminated as she often used to do. I told her that if she continued to do that in either vehicle, she was certain to burn her fuel pumps up and leave herself stranded on the side of the highway at the mercy of any serial killer who happened to be passing by with his machete in his trunk. That little scenario actually worked - it's been at least six months since she's showed up with the empty tank light illuminated in either vehicle....
You may want to take the same approach with Joyce....
Old Dec 27, 2011 | 07:03 AM
Bob Smith's Avatar
Thanks Rick. When it happened yesterday, the tank was indeed just above empty (dist. to empty was 38 mi once the stats started working again)... so there might just be a correlation there. Still wondering though what the fault(s) is/are that the message is supposed to indicate. Couldn't find anything in the JTIS...
Bob
Old Dec 27, 2011 | 07:53 AM
JagV8's Avatar
You're more than a bit hopeful if you expect everything to be in JTIS, especially as it was frozen before your car was built
Old Dec 28, 2011 | 07:22 AM
Bob Smith's Avatar
Ha, well I really wasn't expecting much from JTIS, but I figured I better check it before querying the forum... I didn't want to get the "You need to get the JTIS... best $4 you can spend" replies that seem fairly common... just like the "check the archives" replies (which of course I did).
So... does anyone have an answer on this? Thanks,
Old Dec 28, 2011 | 08:44 AM
JagV8's Avatar
You could refer to the more up to date info on jag's TOPIX. Quite cheap and has more than JTIS, though I reckon JTIS is better value.
Or you might read JTIS about how the system works or the previous threads here, and thus find how it works. The message seems self-explanatory.
You might hope it's not terminal and resolve not to run the fuel low.
Plenty of choices I don't see what more of an answer you could reasonably expect.
Old Dec 29, 2011 | 08:49 AM
bfsgross's Avatar
Bob, did the message disappear after filling her up?
Old Dec 29, 2011 | 10:32 AM
joycesjag's Avatar
In Joyces cases yes.
Shut vehicle off, pump fuel, start vehicle, no message!
Old Dec 29, 2011 | 11:29 AM
JagV8's Avatar
What a great fix!!
Old Dec 29, 2011 | 11:41 AM
bfsgross's Avatar
Ditto.
Old Dec 30, 2011 | 06:38 AM
Bob Smith's Avatar
Indeed it did. No clue as to why though.
Old Dec 30, 2011 | 10:12 AM
Maybe this was Jaguars way of drawing attention to the fact that the driver operated manual fuel pumping system had failed to operate!
Happy New Year!
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
