screen gps failure
Old Nov 11, 2013 | 11:33 AM
fantasy-al's Avatar
Default screen gps failure
hello,
I'm french and my level angais is poor then I am using a google translator.
My vehicle is a s-type V8 end of 2002
My problem is that the central screen does not work, or around buttons, I am heating the bottom ... the bottom screen displays "Ext 50 51"
I have the control connection back al clean the drive and the disk .... (the drive spins "I have unplugged the battery overnight .... still nothing but now more music ... so it must be code the screen
help me
I owns one dvd reference "jaguar hand 1x43 10E898 AD 464210-5024 DENSO PART"
thank you for reading m
alain
Old Nov 11, 2013 | 11:38 AM
fantasy-al's Avatar
me again
and when I press the phone menu and pedant 5 seconds, it nothing happens
thank you
Old Nov 11, 2013 | 12:57 PM
JagV8's Avatar
4.2 or 4.0 engine?
I think you need any newer (sat nav) DVD. It should load the firmware if you put it in and wait. Start the engine first (so that the battery cannot fail).
Old Nov 11, 2013 | 01:39 PM
fantasy-al's Avatar
how just a new disc will solve all my troubles, but I love you .....
what are my opportunities, download and burn a disc (but where to find it), take a hard ... buy from jag ... humm expensive disk
4.2 v8 engine BVA6
Old Nov 11, 2013 | 02:00 PM
fantasy-al's Avatar
but my screen does not react it was when I made ​​the manipulation "phone + menu"?
Old Nov 11, 2013 | 03:20 PM
JagV8's Avatar
Maybe buy from ebay. Does not need to be 2013 (or even 2012). Needs to be newer than what you have now.
(You look to have firmware that does not work. A newer DVD has newer firmware. Do not press buttons!)
Old Nov 12, 2013 | 05:20 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Originally Posted by fantasy-al
... the bottom screen displays "Ext 50 51...alain
This is probably your EXTernal temperature (in Fahrenheit).
Old Nov 16, 2013 | 12:25 PM
fantasy-al's Avatar
good evening
I'll try your jagv8 solution, I wanted to burn a dvd but not managed to find ... so I'll buy the record at surrement naveuro
ps: I'm french but I can be is the difference between a fault code and a temperature in farenheit
thank you to you, I will tell you if it worked or not
Old Nov 16, 2013 | 02:53 PM
fantasy-al's Avatar
after manipulation of buttons, the screen is opened
a menu appears:
diag
hard sw
soft sw
and other ....
What should I look for?
Old Nov 16, 2013 | 03:01 PM
Welcome to the forum Alain, we usually like new members to post in the new member section.
Have you searched the existing 50/51 fault threads?
Old Nov 16, 2013 | 03:46 PM
fantasy-al's Avatar
sorry for not making the rules .... I have a little trouble with the language of Shakespeare
50 and 51 satnav communication problem ....
Old Nov 18, 2013 | 10:18 AM
Ingo's Avatar
LOL language of shakespear.
Hope you got some good advice here.
arivedeti! joking bonne chance.
Old Nov 23, 2013 | 03:54 AM
fantasy-al's Avatar
hello
thousand thank you
I have bought a dvd on the site "naveuro" received in 36 hours!
Performs the update, all the problems Undecided
thank you JagV8
thank you to all
Old Nov 23, 2013 | 04:14 AM
.... I have a little trouble with the language of Shakespeare .......
Magnifique.
Finbarr1975
Sep 5, 2025 08:38 PM
Finbarr1975
Oct 4, 2015 05:32 PM
10 XF Premium
Oct 2, 2015 09:22 PM
mrplow58
Sep 30, 2015 08:56 AM
