Valve cover
Old Jun 22, 2012 | 02:55 PM
usajay38's Avatar
Default Valve cover
what is this sensor called, its in the middle of the picture on the end (front of car) of the valve cover. on each side of motor they are leaking oil, i have searched and not a pvc valve. cant post picture
Old Jun 22, 2012 | 03:10 PM
It looks like you were the guy Jim missed in the intro section and didn't get upgraded.
You need 3 more posts, a visit to the Off Topic section should sort you out, then you can post the pic.
Looks like you made it without the Off Topic stuff.
Old Jun 22, 2012 | 03:42 PM
usajay38's Avatar
photobucket now
Old Jun 22, 2012 | 03:52 PM
abonano's Avatar
Hi, 4.0 V8 I take it...that is a VVT (Variable Valve Soleniod) - there is one on each valve cover. This soleniod controls the VVT actuator, which controls your valve timing. There is a gasket for the VVT solenoid - best bet if your going to change that gasket (which requires you to remove the valve cover) you might as well change the valve cover gasket and associated spark well O-Ring gaskets as well.
Old Jun 22, 2012 | 04:13 PM
usajay38's Avatar
Wow, thanks i also need to find out which cop is misfiring. headed to autozone for them to run codes.
john
Old Jun 22, 2012 | 09:00 PM
abonano's Avatar
john
These COP's are very sensitive and throw random misfires not enough to trip the CEL on the dashboard. Best bet would be to use a COP tester - and test each coil at idle. Another "tell tale" sign of a failing COP is oil in the spark well. If you pull a COP and the bottom of the coil is oil soaked - odds are the COP is shot.
If your VVT seal is leaking oil - more than likely the spark plug well seals are leaking too.
If you have to replace any coils - go with Motorcraft or Jaguar OES coils - or Standard - the other brands out there are taking a roll of the dice. Good Luck.
Old Jun 22, 2012 | 09:34 PM
usajay38's Avatar
thanks for the information.
john
Old Jun 25, 2012 | 01:23 PM
usajay38's Avatar
ok, pulled all coils and none of them wet or anything, the plugs look like the picture attached. went autozone and no codes. should i just replace all plugs and coils or take the car to a jag dealership like wife wants me to so they can run a diagnostic $160.00? is there anyone in the tampa bay area that can help me? the plugs are NGK BKR5EGP
thanks john
Old Jun 25, 2012 | 01:37 PM
abonano's Avatar
thanks john
Hard picture to see - if you have a closer picture that might help.
Here is what I see: your plug shows normal wear - the NGK plugs are designed to go 100K miles before changing. How many miles are on the vehicle? If it's approaching 100K or over 100K I would replace them with NGK double platinum plugs. (Which is OES plug for Jaguar)
On the upper threads on the plug I see oil residue - that tells me you had oil in the bottom of that spark well. Those upper plug threads should be dry, period.
I still think if your going to change plugs and coils you need to change those cam gaskets too. If your not a DIY - take it to an indy, not Jaguar. Changing plugs, coils and cam gaskets is not terribly hard to do - hardest part is removing thr driver's side cam cover - if you have experience you should be able to disconnect the fuel line (with specific tools) but even if not you can still gain enough clearance to get the old cam gaskets off and the new one on and in place.
Old Jun 25, 2012 | 01:55 PM
usajay38's Avatar
ok, i thought it was anti-seize on plug, i can do all work myself. the bottom of coils were dry on signs of oil. i bought the vehicle used, seller gave me records. coils and plugs changed at 77,xxx miles by dealer in 2006 the vehicle now has 134,xxx miles gaskets were also changed then
Old Jun 25, 2012 | 02:51 PM
joycesjag's Avatar
Sorry usajay, I just got home from Tampa 2 hours ago. I would have swung by and hooked you up on my pc. Not that I know the 4.0s but I do have the forum background knowledge.
abonano's Avatar
Anti Seize is a silver color and is grainy - not oily. You have probally 30K to 40K left on those plugs. Since they are NGK plugs I would reinstall them. They are highly reliable. Remember, records are just that records - but +1 on the work being done at the dealership - at least quality OES replacement parts were used.
I would move away from the spark plugs and re-focus your efforts on the coils. I would suggest you consider investing in a COP reader - you simply place the paddle on top of each coil at idle and look for the green/red light and beep - if they're steady, the coil is good - if the lights/beeps are intermitient - you just found your coil issue.
Good Luck and keep us posted on your findings.
Old Jun 25, 2012 | 03:31 PM
usajay38's Avatar
ok, i dont think any local place sells them, i'll check the internet for one.
john
Old Jun 25, 2012 | 04:14 PM
abonano's Avatar
Here you go - you can check Ebay as well. Just be sure the COP tester has a sensitivity wheel like the link below (on sale at www.amazon.com)
Amazon Amazon
Best $$$ I've invested to diagnose these issues.
Old Jul 2, 2012 | 04:19 PM
usajay38's Avatar
ok i bit the bullet and took vehicle to Jag dealer $115 (got wife out of my ear). no codes, the dealer say yes its skipping but we cant tell which cylinder. we commend you replace all plugs and coil $1,200. i asked no way to tell which coil is skipping and they still say no.
also t state housing leaking w/short hose, low tone horn not working.
took my car and told them no thanks.
Old Jul 2, 2012 | 07:41 PM
usajay38's Avatar
replaced left bank plugs and coils, smooth ride. after vacation will replace vvt seal, replace horn, and i try to locate t stat small hose.
john
Old Jul 2, 2012 | 07:42 PM
abonano's Avatar
COP Tester could have saved you replacing 3 coils - hopefully you used good quality coils...
Old Mar 10, 2013 | 08:19 AM
usajay38's Avatar
Is this a good valve cover gasket set from RockAuto, does it have all the O rings I need for both side, the ones needed for the VVT seals?
VICTOR REINZ Part # VS50397
Old Apr 7, 2013 | 04:31 PM
lglamb's Avatar
Pretty sure the VVT seals are seperate.
Also recommended is Felpro kit (see '90* Lincoln LS 3.9)
(doing concurrent research)
Lowell
Old Apr 7, 2013 | 05:20 PM
JagV8's Avatar
It's been a month so kinda late...
dsnyder586
Dec 29, 2024 07:39 PM
xjrjag
Oct 24, 2024 03:09 PM
bamforp
Aug 14, 2024 05:36 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
