01 with too many engine codes!
Old Mar 1, 2021 | 10:21 AM
JagV8's Avatar
Originally Posted by Desertdawg
Can codes be cleared w/o a scanner?
No.
(Technically a "scanner" could not clear codes but I know what you mean.)
The idea is you perform a fix then clear the codes if you don't mind taking a chance that's a mistake, instead of waiting for the codes to self-clear (which they do if it's actually a fix).
Old Mar 1, 2021 | 05:15 PM
Desertdawg's Avatar
Originally Posted by JagV8
Basically:
1. clearing does not fix anything
2. you haven't (yet) been unlucky and found yourself in Catch-22 where monitors can't set so the car can't tell you codes - but as has been posted that is what does occur occasionally
Ok, thanks. My code reader on my '98 Ford V-10 motorhome clears the active codes, but they re-alarm right away. This reader doesn't work on the '98 XJ8. It's at a good shop now to get a fresh start.
Old Mar 1, 2021 | 10:20 PM
davidladewig's Avatar
Originally Posted by Julia Cameron
You guys have a lot of helpful information, I really appreciate it. So far we have not had any lights come back on at all. We have filled the tank up and driven it. All we've done was replace the battery with one that has 1100 CCA, and we bypassed the canister purge valve. It seems to be running better, only felt a couple sputters when it was being driven.
Good move on the battery. 500 CCA's is what you start lawn tractors with (joke) A lot of those codes can be battery or a silly vacuum leak. I had a leak. It was a $5 part, the vacuum check valve on the power brake booster. I also have and Icarspot code reader that is just for jag/land rover. I got it on ebay and it seems good for part time wrenchers like me. Good luck .
Kewpie
May 24, 2017 12:44 PM
Tarik
Nov 2, 2014 02:09 PM
WaterDragon
Oct 11, 2012 01:55 PM
The World Tour
Jan 9, 2012 01:35 PM
