03 s Type 4.2 coolant inlet pipe leaking
I had to replace my thermostat housing assembly on my s Type 4.2 na, after completed I can’t get the coolant inlet pipe to seal. It keeps leaking from where the o-ring is. I’ve pulled it apart and tried different new housing assemblies and still leaks.
Did you lube the o ring with coolant before install?
Did you torque unit down to factory spec?
ln69bt
46
May 26, 2018 01:39 PM
