03 stype r rotor brake set package
Old Feb 15, 2013 | 09:01 PM
carlorner's Avatar
Default 03 stype r rotor brake set package
my car sat for 15 months without being driven, rotors were new, now they are slightly warped.. should i resurface them????? or who/where is the best place for a decent set that wont brake the bank, i know dont have much time to search so please help.
Old Feb 15, 2013 | 09:22 PM
Mikey's Avatar
Why do you think they are warped? This doesn't happen during storage.
Old Feb 15, 2013 | 09:49 PM
cbharley10's Avatar
I would question the rotors being warped, that shouldnt happen with sitting.
It may be a different issue all together and probably worth having looked at.
If you do end up needing rotors there are several out there for the STR but the guys at Brake Performance have some pretty good deals on the dimpled slotted rotors
www.brakeperformance.com
Old Feb 15, 2013 | 10:03 PM
heima's Avatar
I am going to guess it is this: stored outside, rust develops on the disc, except the portion where the pads are located. Gentle brakers will feel a pulsation in the pedal when the car is driven as the pads pass over rusty, then clean spots on the disc. It will be this way until the rust is worn off.
So, do the discs look rusty?
How about some sporty driving.
Do you feel a pulsation in the pedal now?
Old Feb 16, 2013 | 01:39 AM
carlorner's Avatar
Default details
yes it sat outside in all weather seasons here in pa, they look rusty and the sterring wheel shakes a little bit, they were only a bout 1,000 miles on them when it was parked
Old Feb 16, 2013 | 09:37 AM
Mikey's Avatar
Then you just need to drive it and do some agressive braking to get the surface rust off. If that doesn't appeal to you, take it to a corner garage have them use a rotary sanding disk. This is a very common repair that they do to remove accumulated brake pad material that causes the thumping and steering wheel shake.
Do NOT have them 'turned' on a machine!
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
neruda
Oct 18, 2015 01:19 PM
handcuffsready
Sep 7, 2015 01:02 PM
JagLove86
Sep 6, 2015 10:36 PM
