2 Bolt Self Sealing Flange Down pipe
Old Mar 16, 2016 | 11:06 AM
edankeven's Avatar
Default 2 Bolt Self Sealing Flange Down pipe
Hello,
Anyone have knowledge on the 2000 S-Type Exhaust system 2 bolt self sealing flange? Is it reliable? Would modifying a gasket for it be a bad idea?
Old Mar 16, 2016 | 06:14 PM
gm_jim's Avatar
This is my third S-Type. The first two (2000, 2002) did not have a problem with the flange. The current car did work itself loose (or wasn't tightened enough by the previous owner) on one bank. This triggered the MIL and a scan showed a lean condition on bank 1 (P0171). Tightening the bolts cured the problem. Others on this forum have reported similar experiences.
The flange bolts are one of the easiest parts of these cars to service. I'm not sure it would be worth the trouble to reconfigure the flange to manifold sealing.
Old Mar 18, 2016 | 07:58 AM
clubairth1's Avatar
Community Influencer
Should a simple fix at any exhaust shop?
Old Mar 21, 2016 | 02:43 PM
edankeven's Avatar
Do you know the part number for flange bolt/stud replacement?
Old Mar 23, 2016 | 09:48 AM
edankeven's Avatar
OK so if anyone needs to know
XR836503 is the part number for the self seal flange STUD.
XR82889 is the nut.
SinF
Mar 24, 2016 06:39 PM
WinterJag
Mar 23, 2016 02:40 PM
3434char
Mar 20, 2016 08:48 AM
TexMurphy
Mar 15, 2016 04:01 PM
ziad993
Mar 12, 2016 10:19 PM
