2000 jaguar s-type 3.0 fan staying on
Old Oct 10, 2010 | 10:27 PM
lcyoung's Avatar
Default 2000 jaguar s-type 3.0 fan staying on
hello i got a 2000 jaguar s-type 3.0
in my radiator fan stays on even when i turn my car off.. it also has a slight hesitation when i first crank it up. and pull off.. then when i drive the hesitation stops. in drives normally..one more thing the temperature hand goes up and down.. but the car never run hot... do you think it can b a sensor or some
Old Oct 11, 2010 | 07:55 PM
Glockjag's Avatar
Have you done a tune up at least? SAme thing happen with me..... Just did the usual maintenance, check all fluid levels, it happen to me and solved the problem on my 01'.
Old Oct 12, 2010 | 02:07 AM
JagV8's Avatar
It may be the ECT sensor. It's VITAL to proper running. (And cheap to change, but check wiring etc as well.)
Old Oct 12, 2010 | 06:09 PM
lcyoung's Avatar
Yeah I just did the tune up. All spark plugs and coil pack. I was low on radiator fluid. So that was one of the problems. But the fan still staying on. When I cut car off
MJ'S Jag
Nov 10, 2022 08:14 AM
tonimccloud
Sep 3, 2015 07:58 PM
nelsonht
Aug 30, 2015 06:01 AM
EastFalk
Aug 29, 2015 08:22 PM
NinoGrimace
Aug 26, 2015 05:15 AM
