2000 Jaguar V8 4.0L misfire
Old Jun 8, 2013 | 10:09 AM
jagboy96's Avatar
Originally Posted by abonano
2000 S Type - 4.0 - 210,950 miles - newest all metal tensioners and guide rails - installed.
would a chain slip cause low fuel pressure?
Old Jun 8, 2013 | 04:13 PM
abonano's Avatar
No, I don;t believe so - if the chain slipped - low fuel pressure would be the least of your worries.
Old Jun 8, 2013 | 08:30 PM
jagboy96's Avatar
then it must be the pump or a hose connecting to the pump or the nylon screen got water on it
Old Jun 8, 2013 | 09:22 PM
plums's Avatar
There are only 4 things that can affect fuel pressure on this system:
-- fuel filter
-- fuel pump
-- fuel pressure regulator at the rail
-- fuel pump power/ground lead resistance
Old Jun 9, 2013 | 02:54 AM
JagV8's Avatar
And #5 / #6:
module(s) that drive(s) the pump (STR has 2, others just 1)
Don't rush to suspect the module(s). You tend to get codes if bad.
Old Jun 9, 2013 | 01:46 PM
jagboy96's Avatar
its not the module but its not the main fuel pump (RH side) could it be the LH side pump?
edit: update: put in a new fuel pump on RH side, ran for codes, heard noise in engine, figured out it was the tensioner which means the chain slipped which mean the cam is out of order causing a miss
Old Jun 10, 2013 | 06:48 AM
abonano's Avatar
OK - I'm somewhat confused... You replaced the fuel pump - heard a noise and now you think it's the tensioner? Did you pull off the cam covers to check for alignment of the cams as mentioned above? (You would have to turn the crank to see if the cams are aligned)
To add - if the cam/chain skipped a tooth - you wouldn't only have a misfire, but multiple misfires across the cylinder bank and your engine would run like crap. If I recall correctly - your original misfire was only in Cyl #4 - correct?
Old Jun 10, 2013 | 07:45 AM
  #28
abonano's Avatar
Too add... Regarding Cyl #4 (Passenger Side - most rear coil) - this cylinder and Coil #8 (Driver's Side - most rear coil) are most susceptible to oil intrusion into the spark well - I would double check the spark well with a flash light/inspection camera - any oil (even if it's sitting at the very bottom of the well) is troublesome and any rust color soot in the spark well or on the coil boot is indicative of water intrusion - which is also troublesome for the coil.
Keep in mind - any of these coils can exhibit intermittent issues at start up but more so when the engine is hot.
Old Jun 10, 2013 | 11:23 AM
tbird6's Avatar
I agree! Before you give up pop one of the cam covers off and take a look.
It's well worth your time at this point.
Maybe even post a picture or two?
Old Jun 11, 2013 | 04:46 PM
  #30
jagboy96's Avatar
ill see what i can do.... sometime this week or weekend ill pull that plug out and look inside
aode06
Jul 28, 2023 02:26 PM
dpappyp
Sep 29, 2015 01:28 PM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
corysansburn
Sep 10, 2015 06:15 AM
