2001 double din
Old Oct 28, 2023 | 10:20 AM
Wtm812's Avatar
Default 2001 double din
I saw on here somewhere someone asked if anyone had installed a double din aftermarket deck into a 2001. Yes, I have successfully and it was pretty easy after figuring out there wasn't a shortcut. You're going to have to breakdown the entire cage that holds the storage and factory radio and build up it back together starting with your double din.. You won't be able to use the security locking cage that comes with the aftermarket unit because the cars cage will screw to the deck. After putting both sides on aftermarket deck then you can reinstall the storage box to its right side. You won't be able to put the top metal brace back on because the deck will be slightly too tall but it will still fit and bolt back into your dash securely. Hope this helped
Old Oct 29, 2023 | 02:14 PM
clubairth1's Avatar
Community Influencer
Or you could use one of many adapter kits?
Like this one for $35?
Double Din Adapter Kit for S-Type Double Din Adapter Kit for S-Type
They even have an adapter harness for an additional $9 or so. Would that work?
2001 White XJ8
Apr 9, 2022 05:46 PM
shall
Dec 21, 2020 12:05 AM
Signified2106
19
May 16, 2018 12:35 PM
mikchek
May 16, 2018 10:35 AM
raypendergraph
Apr 23, 2008 07:26 PM
