2001 S-Type 4.0 Oxygen Sensors
Old Jan 27, 2017 | 08:48 AM
Dionne Kae Dickey's Avatar
Default 2001 S-Type 4.0 Oxygen Sensors
Several questions:
How many oxygen sensors are on my car?
Where are they located?
Are they difficult to replace?
Do you need any special tools to replace them?
Old Jan 31, 2017 | 11:58 AM
jerry_hoback's Avatar
Hi Donna, I'm sorry I don't know the answer, but you would probably be better posting you question in the S-type section. Good luck
Old Jan 31, 2017 | 12:41 PM
Originally Posted by Dionne Kae Dickey
Several questions: .....?
Dionne,
I've moved your question from US Midwest Region to S-Type forum. This is the place to post technical questions about your model.
Old Jan 31, 2017 | 01:13 PM
JagV8's Avatar
4. 2 per cat. Codes normally show which if any is bad and then you change it/them.
Old Jan 31, 2017 | 03:00 PM
Ducmon's Avatar
If you go to the stickies at the start of the s type you can download a copy of the JTIS. This the electronic workshop manual for the Jaguar this will be a major help for you.
Old Jan 31, 2017 | 04:29 PM
kr98664's Avatar
What fault codes are you getting? It should be a 5 character code, starting with the letter P and followed by four numbers. ​​​​​​Please post the actual code, not what the scanner says it means. Some scanners don't know certain Jag-specific codes and you can get misled by the fault description.
Old Jan 31, 2017 | 05:07 PM
docs427's Avatar
You also need to watch how they are switching, as long as they stay in range they wont set a code but they do get lazy with age. There are 2 at the inlet sides of the cats and 2 in the center of the cats. 7/8 wrench will remove them but if they have been in there a while they may be tough to get out. If so cut the wires off them and use the box end of a wrench so as to not round them off while trying to remove.
Adventure100
Oct 21, 2016 09:43 AM
JB73
Oct 2, 2016 05:22 AM
Jul 26, 2010 06:00 PM
Dec 31, 2006 02:09 AM
Jan 15, 2006 02:29 PM
