2001 wont start after removing door panel
Old Feb 2, 2013 | 10:05 AM
Bufort L. McClerkin Jr.'s Avatar
Default 2001 wont start after removing door panel
Hi, i just took the drivers door panel off my 2001 3.0 S-type, disconnecting a white and a blue connector in there from the window buttons and the speakers so i could fully remove it. (this was to get to the window mechanism which has broken). I then plugged them back in, windows working again, put the door panel back on, and now the car wont start. The dash lights come on, and the red light on top of the dash by the window flashes, and nothing electrical in the car works now, not even the windows, which did 10 minutes ago.
ive taken the door panel back off now to make sure i hadnt disconnected something whilst putting it back together, but it all seems fine.
is this some kind of anti-theft prgram that has kicked in? i havent even disconnected the battery or touched anything else other than in the door.
The doors wont even lock now using the fob. Whats happened?
Old Feb 2, 2013 | 10:23 AM
joycesjag's Avatar
How long did you have the door open(?) enough to have drained the battery down to the point where there is not enough juice to start?
Maybe toss a charger on it for a bit.
Nothing with what you did to the door should have anything to do with the no start.
Old Feb 2, 2013 | 10:31 AM
steveinfrance's Avatar
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
Old Feb 2, 2013 | 11:31 AM
GT42R's Avatar
Sounds like dead battery... creeps on up on you at the most unexpected times,
Old Feb 2, 2013 | 11:32 AM
only about 45 mins. i aso tried something another thread suggested: locking the door from the inside and then opening with the key; to no avail.
the car did give a few chirps of the alarm, but i stopped that with the fob before alarm really went off.
I've also read somewhere that the flashign red light gives a code after 1 minute, (such as 1 flash and then 6 flashes meaning a code 16), but it just seemed to flash consistently slowly and i gave up counting at 20 flashes.
also, when i turn the ignition, all the lights which were on in the dash turn off except fot the drivers airbag light, and even the fuel gauge goes down to 0 too.
I'll give it a go charging the battery overnight...
Old Feb 2, 2013 | 11:41 AM
JagV8's Avatar
Sure does sound like it's too flat for the car. There's a huge draw on attempted start.
Old Feb 3, 2013 | 08:02 AM
joycesjag's Avatar
Was it the battery?
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
