2002/3 STR throttle dead spot?
Old Nov 27, 2011 | 07:51 PM
the beagle's Avatar
Default 2002/3 STR throttle dead spot?
HELP! I have a 2002 pre production 2003 S Type R (4.2L with Eaton supercharger) runs well, just had a tranny service and software update, however there seems to be a dead spot in the throttle (it was there before tranny service) when I am crusing on the freeway and want to accelerate/kickdown to over take etc, car takes a deep breath?, howls then it goes into limp home mode. gear box fault on dash! Revs around 2000-3000 depending on speed at the time of acceleration.Stop car, turn off ignition, restart all OK. Got me stumped. Anyone else had a similar problem.
Old Nov 29, 2011 | 06:42 PM
uropnm6's Avatar
When this happens do you get a check engine light? if so check the code before you restart, then you can diagnose.
Old Nov 30, 2011 | 03:27 PM
the beagle's Avatar
No there is no check engine light, just the orange/amber light to the left of the LCD display comes on and "gearbox fault" in the LCD.
I did read on another site that it may be a vacuum leak somewhere?
I cant check it at the moment, a #*@)!* L plater drove into the side of my car the other day and its in the smash repairers at the moment.
Old Feb 15, 2012 | 09:11 PM
the beagle's Avatar
Howl fixed,gear change fixed.
I think it was a combination of a good clean (throttle body, took 2 mins) and more to the point, the battery was old and not holding a charge, replaced battery, reset codes all ok, no probs now for over 2 months.I have been told before that if you get"wierd" probs with an STR check the electrics first. Thanks for you help
Old Feb 20, 2012 | 03:41 PM
StypeRowner's Avatar
Default Battery fixes.
Glad you got her fixed Jim.
My clue to a battery change was an observation by members of this great forum noting that erratic auto up/down window operation can be an early warning for a battery problem. Since mine was almost 6 years old I changed it and it fixed the window problem and probably saved many an ulcer too.
Happy trails !!!!!!!!!!!!!!
bdboyle
Sep 16, 2019 05:58 PM
Nigels420G
Mark V - X 420G
Sep 27, 2015 03:48 PM
SoCalJagS
Sep 27, 2015 09:20 AM
thedugger1
Sep 26, 2015 10:27 PM
