2002 S-Type 3.0 idle studdering & loss of power
Old Nov 1, 2010 | 12:21 PM
Brogi's Avatar
It could be the Differential Pressure Feedback EGR, which is situated at the back of the manifold. Try taking of the pipe leading to it and blocking the valve and the pipe. If the car runs ok, thats your problem. You can actually run it like this, but the emmisions will be thrown out.
Old Nov 1, 2010 | 04:44 PM
steve11's Avatar
ud
If I've read your list carefully enough, you've missed the two far more common sources of vacuum leaks on the S. Picking up from what Brogi suggests (and I agree), inspect the plastic tubing going to the brake booster. This plastic pipe cracks often. Second, check the PCV hose going from the front cam cover to the intake manifold. This pipe too cracks often.
If you've done this already, then I'd need to think more deeply through your issue as you're replaced (new parts, I assume) everything that could contribute to a problem like this.
The two more critical parts that could cause trouble and lead to the Cats failure are the MAFS and the O2 sensors. My experience with the S is that the designers peaked out the MAFS. It operates within a very tight range and I personally would not replace it with anything other than a factory MAFS. Same thing with the O2 Sensors. If you replaced these with some broader ranged or cheap O2 sensors, then you might not be done yet.
Old Nov 3, 2010 | 09:56 AM
thatguy's Avatar
The only thing I see on your list that you have not done is the breather elbow for the crackcase system. This is in the back of the engine under the intake the lower is always a problem on the 3.0L, sometimes to upper is bad. There was a bulletin for the upper but not the lower.
Dicque
Sep 19, 2015 12:53 PM
the whittys
Sep 15, 2015 01:47 AM
DatDude
Sep 8, 2015 11:36 PM
Numwen
Sep 6, 2015 12:30 AM
Bowman
Sep 3, 2015 03:17 PM
