2003 3.0 v6 open loop & shaky on cold starts
Old Sep 25, 2024 | 03:52 AM
Tec_9's Avatar
Default 2003 3.0 v6 open loop & shaky on cold starts
My 2003 s-type v6 is running very rough on start up and perfectly fine once it's warmed up. On cold start it shakes a lot and the rpms dip below 500 which turns on the battery light. The voltage also jumps around from 12.7-14.4. it's also in open loop was thinking it could be the MAF any thoughts?
Old Sep 25, 2024 | 08:48 AM
S-Type Owner's Avatar
Rather than guessing, perhaps checking the condition of your battery/charging system (you have omitted your location, which is no help to those who will try to help you); here in the states most auto parts outlets will check your charging system and run a load test on your battery free of charge.
After making sure the battery and charging system is in good shape, a diagnostic code reader can be employed to dig deeper. Please be aware that many "el cheapo" code readers attach incorrect definitions to the OBD-ii codes read from a Jaguar's engine management system (and other sub-systems too).
Teddy000
Sep 11, 2024 09:34 PM
knares
May 11, 2022 10:49 AM
Uncle Fishbits
Nov 30, 2019 04:47 PM
petrj
General Tech Help
Feb 17, 2018 04:18 PM
chuckdog_5
Jan 5, 2013 08:29 AM
