2003 Jaguar S-Type V6
Old Jan 9, 2016 | 06:07 PM
Imprenion's Avatar
Default 2003 Jaguar S-Type V6
Recently got a Jaguar from someone who kept it in maculate condition. The only thing it needed was new break pads which were fairly cheap and easy to replace. I do have a park brake fault however and a ABS/DCS fault that comes on as well at random, but eventually goes away. My cruise control doesn't work when this happens. Also had a check engine light come on and had a random transmission issue happen this morning which went away as well. I believe that could be a rear wheel sensor issue, along with that 5th gear or so. I can go get the codes if anyone wants them. I kept all the gathered info in my glove box. Just want to make sure every minor or major thing gets fixed so this vehicle last a long while. That last thing (just remembered) is a rear reverse or parking light that seems to work on and off (loose wire maybe)? I'm not entirely mechanically inclined, but I'm learning heh.
Old Jan 10, 2016 | 06:26 AM
joycesjag's Avatar
Welcome to the forum. Here are a couple of things that you will want to do. First go to he new member sub directory and properly introduce yourself per forum protocol. This has many advantages. Secondly go to UserCP, scroll down to edit signature, click, add your vehicle details "2003, 3.0, mileage etc., this will help us help you without having to ask for that info.
Onto your problem, you might want to check your batteries condition and year. There is a ton of information about "Battery Failing" in the archives. Here is one of the many: https://www.jaguarforums.com/forum/s...e-stuck-32699/
Old Jan 10, 2016 | 11:25 AM
Imprenion's Avatar
Thank you for the information. I did edit the signature with the vehicle details, but can't seem to find this member sub directory for the introductions. I'll check the battery later today. Just got some initial bad weather.
Old Jan 10, 2016 | 11:31 AM
joycesjag's Avatar
Sorry, phone is acting up, I couldn't paste link.
"New Member" its one of the first boards.
Old Jan 10, 2016 | 12:01 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
New member forum...
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
You MUST fully charge your battery before doing any troubleshooting on these cars. Once that is done, clear the codes with a code reader and drive the car for at least 50 miles. Then read the codes again.
Lots of time, trouble and expenses can be avoided if you fully charge your battery before troubleshooting. See my link below in my signature.
Jaguar Forums Editor
Jaguar Press release
Jan 12, 2016 11:14 AM
Tahoe Dave
Jan 4, 2016 09:26 AM
fox5mx101
Dec 24, 2015 11:54 PM
mutu88
Dec 16, 2015 03:10 AM
GlynS
Dec 13, 2015 09:52 AM
