2003 Power Door Lock Problem
Old Jun 10, 2014 | 10:43 PM
Azcat's Avatar
Default 2003 Power Door Lock Problem
A coworker of mine has a 2003 S-type with a door lock problem. She removes the key from the ignition, exits the vehicle, hits the lock button on the keyfob, and the doors will lock for a moment and then immediately unlock. The same thing happens if she uses the key from outside the vehicle.
Any ideas?
I know some vehicles cycle the lock in a similar fashion when attempting to lock the vehicle with a door open and the engine running, but that is a safety feature, and I do not see any connection with this issue she is experiencing.
Thanks,
Old Jun 15, 2014 | 11:45 PM
dlnga's Avatar
Could be one of the doors is not responding to the drivers door "telling" it to lock so when the other doors all lock, the unlocked door causes a default and unlocks the others, if that makes any sense...I had the same issue and found that the rear door behind the driver was not locking so I manually locked it and everything works fine, that door just stays locked for now..No one ever rides in my backseat so what do I care...
Old Jun 16, 2014 | 03:50 PM
jagastruckerhoodornament's Avatar
Check each door by manually locking per the above post. If a manually locked door does cause your remote locking to stay locked, may be an actuator. There is a cheap plastic component in there -- broke on my rear passenger's side door.
Forum member joycesjag posted this teardown with pics a while ago - complicated DIY job...
https://www.jaguarforums.com/forum/showthread.php?t=65657
Old Jun 17, 2014 | 11:11 AM
joycesjag's Avatar
As mentioned above one of your door lock actuators failed. The most common one is the drivers side rear, also mentioned.
Here's my link for repair:
https://www.jaguarforums.com/forum/s...ics-faq-65657/
msdg137
Sep 16, 2015 06:24 AM
Thia
Sep 1, 2015 10:36 AM
plmmd
Aug 31, 2015 10:07 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Terrance Williams
Aug 26, 2015 11:50 AM
