2003 S-Type engine and transmission help!!!!
Old Nov 15, 2011 | 10:06 PM
Siueparent's Avatar
Default 2003 S-Type engine and transmission help!!!!
I have a wrecked 2003 3.0l S-type wrecked in front and a 2005 3.0l s type wrecked in rear. Will the 2005 sub frame, engine, trans fit in the 2003. What I really need to know if the all the plugs, connection from the 2003 trans are the same as the 2005? Thanks
Old Nov 16, 2011 | 01:15 AM
JagV8's Avatar
Better worry more about the computers. Check VIN of the 2005 - after the change to more CAN and diff PCM? There's a fair chance it won't work electronically and no amount of reflashing will solve it.
Old Nov 16, 2011 | 07:21 AM
Siueparent's Avatar
I was going to use the 2003 pcm I need to know if the engine compartment wiring for the 2003 the same for the 2005 trans connections and the engine connections. So can I just unplug the trans and engine from the 2005 and just plug everything back into the 2003.
Old Nov 16, 2011 | 08:46 AM
JagV8's Avatar
It won't work if what I referred to applies.
Old Nov 16, 2011 | 10:28 AM
Siueparent's Avatar
Thanks. Guess I'l try to fix both of them now. So a 2000-2004 3.0L engine and trans will work with the 2003?
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
