2003 s type r vvt issues
Old Aug 14, 2015 | 10:19 PM
kert1224's Avatar
Old Aug 14, 2015 | 10:21 PM
kert1224's Avatar
So those are while driving. Which one is reading correctly? Are either of them? I don't know what it should look like but I imagine it different then what's actually happening.
I took the plugs out (obviously), when I reassembled I put the plugs back in on the same side, different order. When I put the coils back I switched sides
Old Aug 15, 2015 | 12:45 AM
JagV8's Avatar
May be the wrong plugs. Should be iridium, e.g. NGK IFR5N10
You can't check a cat by smell.
Old Aug 15, 2015 | 02:12 PM
kert1224's Avatar
They are iridiums. Ngk brk5iex-11 auto zone has down the same number for my car. It also brings up that number on the ngk site with an option of 5 different ones.
http://www.ngk.com/product.aspx?zpid=9311
And do cats not smell funny when they are bad anymore? When did that stop?
Old Aug 15, 2015 | 02:40 PM
kert1224's Avatar
Ngk site with their options for plugs...
http://www.ngk.com/Automotive-NGK-c1411.aspx
Old Aug 15, 2015 | 03:16 PM
Mikey's Avatar
A plugged up cat (like Cambo had) does not give off the rotten egg smell as would a failed cat.
I doubt your problem is the plugs themselves but one or two do look a little different than I would expect. I'd spend more time with the random misfire code.
Old Aug 15, 2015 | 11:52 PM
clubairth1's Avatar
Community Influencer
Just for more background. The SC 4.2L finally got VVT in 2006. What you read was correct but for the 4.2L NA.
stanjag
Dec 29, 2024 08:26 PM
ClassiXtype
Oct 22, 2023 05:29 AM
big d
Sep 3, 2015 07:37 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Terrance Williams
Aug 26, 2015 11:50 AM
