2003 Type S Drivers power window part #XR 842604
Old Jun 18, 2022 | 05:19 PM
Warrende's Avatar
Angry 2003 Type S Drivers power window part #XR 842604
This is the driver's window channel and is unavailable in good shape anywhere so my window is inoperable. HELP!!! I am not very computer savvy so I have no idea how to get help other than this post.
Bye
Last edited by GGG; Jun 21, 2022 at 04:45 AM. Reason: Remove eMail address - not needed for replies
Old Jun 21, 2022 | 04:44 AM
Welcome to the forums Warrende,
I've moved your question from Interior to S-Type forum. Members here with the same model will be able to help.
I can't find that Part Number in the catalogue. It will help if you describe the part you need.
Old Jun 21, 2022 | 05:30 AM
S-Type Owner's Avatar
The following site, located in Germany, shows the part and it loads into a shopping cart; but, they have a minimum 250 Euro order requirement.
Search by original / genuine spare part number (carparts-pros.com)
Have you checked with a Jaguar dealer? I realize that the part appears to be discontinued, but dealers have the ability to poll the dealer network to see if a parts department has the item in inventory as NOS.
Old Jun 21, 2022 | 10:33 AM
Warrende's Avatar
Default 03 S Type power window issue
I believe you can't find the part # XR 842604 is because Jaguar has discontinued its manufacture. I have seen a used one, my mechanic called it a window channel. It looks like a weatherstrip; it's a circular belt of relatively thin rubber, grooved I believe for the window to ride on and had to be lubed once,(which fixed the issue), about a year before it collapsed completely. Thank you so much for your attempt to help. The car isn't even saleable in its present condition. The window will no longer work and has had to be kept closed Again, Great Thanks, Warren
Old Jun 21, 2022 | 10:37 AM
Warrende's Avatar
Default 2nd Reply
If the place in Germany is the only place I can get it, I would be willing (quite unhappy though), to pay the 250 Euros as the vehicle is, as said not even saleable, though it is my wife's car and I don't want to sell it. Warren
Old Jun 21, 2022 | 02:57 PM
kr98664's Avatar
Where are you located? It's not stated in your profile. Your approximate location will help determine if certain options are cost-effective.
You've mentioned searching for XR842604 (leave out the space for best results) but have you tried XR826509? According to several web hits for the first number, this second number is the old superseded version of the same part. Often the changes are very minor, and the superseded part will still work just fine. I've had very good luck finding discontinued parts on eBay, although I'm not seeing anything at the moment. Keep looking, though, as dealers and wholesalers are cleaning out old inventory all the time.
Another option is to get an entire door assembly from a wrecking yard. I had a big decorative landscaping boulder jump out and mangle one of my doors several years ago. I found a complete door on eBay for only $125. Shipping was more than the door, unfortunately. I had several choices locally in different colors, but only found the same color halfway across the country. If you only need to rob one part from it, you may be able to pick up something locally if the color doesn't matter. If you find a local source, they may work with you and sell you just the pieces you need.
Another good source for used parts, a user-friendly database of wrecking yards:
https://www.car-part.com/
Old Jun 21, 2022 | 03:38 PM
Warrende's Avatar
Default 2003 Type S Driver's window channel
Karl, I am located in Houston, Texas, USA and have purchased a used one already from Ebay. It was not in good enough shape for my mechanic to install, (per him), and he said it has to be new or like new for him to do all the labor necessary. XR826509, per Jaguar, was superseded by my part, XR842604, now discontinued. I also asked the guy at Jaguar parts if one could be on a shelf at any other dealership and he said that would come up automatically when searched for, thus not available. However, if you could get me the place in Germany and how to contact them, I'll be able to afford the part, though not happily. Thank you soo much for your help, t'was truly appreciated. Warrende
Old Jun 21, 2022 | 08:49 PM
NBCat's Avatar
Contact SNG Barratt, one of the forum sponsors, and ask if XR825644 would be suitable for your VIN as it's still available.
https://www.sngbarratt.com/English/#...4-6f03b9d05930
Old Jun 22, 2022 | 01:15 AM
neilr's Avatar
Sorry to be the bearer of bad news, but those German sites just work with a massive database of part numbers and official prices with no regard to available stock. You order and they start the procurement process from the car manufacturer. As soon as it becomes clear that there is no stock, the order is cancelled and your payment is returned. They do work fine for newer stuff and are trustworthy, but as parts become rare, they are as helpless as the rest of us.
Good luck,
Neil
weasel
Nov 30, 2014 05:40 PM
weasel
Nov 29, 2014 08:40 AM
Leichardti
Sep 6, 2014 04:35 PM
Jag Pilot
Jul 4, 2013 10:09 AM
EZrider800
47
May 16, 2011 01:14 PM
